Hypex DLCP no analog audio output (help needed) - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 10th January 2016, 08:29 PM   #1
Default Hypex DLCP no analog audio output (help needed)
Problem: I am not getting any output on the analog outputs.
Steps taken:
I've updated the firmware to v2.1. I've created a basic configuration with unity filters in each biquad position and downloaded my filter configuration to the DLCP. I've tried analog, USB, S/PDIF and Optical inputs. The DLCP seems to boot and operate correctly. The control board recognizes the DLCP. The Filter Designer v4 connects to the DLCP.
Configuration:
DLCP with v2.1 firmware
DLCP Input Board
DLCP Controller board
SMPS DLCP Power Supply
Filter Designer 4 (beta)
Old 13th January 2016, 02:22 AM   #2
Default Pictures of DLCP board and cabling
I've added pictures showing the DLCP and it LEDs, the cable connections between the PS-DLCP-Input board and the Filter Designer version. I've reflashed the firmware and created a new config file. Still no audio output. Also, I have tried different sources.
Any trouble shooting suggestions will be greatly appreciated.
Thanks,
Jim
Old 18th February 2017, 10:35 PM   #3
NCP is offline NCP
Hi James. I'm seeing that you have the DLCP connected to the host computer and communicating correctly, with firmware updated all the way to V2.3 right? In that case open the control panel in the software where you tell the DLCP which input to use... that control panel. You will see a control for input level, mute and a window displaying the input level value. There is a bug- at least for me- where everything flips out if you slide the slider but if you directly enter the value in the input level window it works. By default it is at -96. Enter 0 there for unity gain and you should now have output.
Hypex NC1200, DLCP, Ian FIFO, WaveIO, Neotech wire, Xhadow+Mundorf con, Lundahl choke edbk Swap Meet 30 24th June 2015 01:40 PM
Hypex DLCP - standby mode georgeus Digital Line Level 0 12th June 2015 06:38 AM
FS: Sitronik Amps, Hypex DLCP, Thel Power Supplys Guitarfreak Swap Meet 5 12th February 2015 02:53 AM
FS: Hypex DLCP and input board mcai7et2 Swap Meet 1 5th November 2013 06:11 PM
installing an analog audio output jack on a television? peace brainerd Analog Line Level 7 8th January 2012 07:38 PM
Copyright 1999-2017 diyAudio
