Mini DSPs or computer + sound card
Old 8th January 2016, 02:07 PM   #1
Kev06 is offline Kev06  England
Default Mini DSPs or computer + sound card
(this post is about choosing between digital line and PC based approaches so I had to choose one or the other forums, apologies if you don't think it fits properly)
I need 'effectively' a pair of 3-way active crossovers plus linkwitz transforms, to run a pair of 3-way stereo speakers. The transforms are needed because the bass drivers are purposely in undersized sealed enclosures. (My sources include analogue line but are mainly computer based, and are mainly audio but with occasional video/film). There are different ways of doing this, so I've asked a few questions around the subject and narrowed it down to my two favourites:
1.) A pair of 2x4 miniDSPs. Purpose made for this kind of thing and would be very straight forward wrt usability - in combo with my existing stereo DAC they could allow almost any source via physical connectors or a selector knob and pretty much just do what they say on the tin. However, it seems like a fairly messy signal path for my main software-based source - there'd be first a usb DAC and then also the mini DSP's internal A/D and D/A processing. I'm a little concerned about the effect on sound quality and also latency on those rare occasions when I play video with the sound.
2.) A netbook/laptop plus decent USB surround sound card (like the asus xonar u7) would be a shorter/simpler path for native software playback (employing just one D/A step). It should be possible to set up XO and EQ in my existing playback software (JRiver), and theres the potential for linux alternatives (if I ever get to grips with them) and other wizziness in the future. But IMO it can be a faff dealing with different sources and line inputs on a computer, and theres always the chance of sounds not coming through the playback software (which would therefore bypass the Xover etc.).
So, I'd like the miniDSPs but suspect the laptop/soundcard approach may be inherently more suitable (given that software is my main source). And hence I'm dithering yet again. What do people think - am I worrying too much about the signal path etc?
Many Thanks
Kev
Old 10th January 2016, 11:25 PM   #2
Foxx510 is offline Foxx510  Australia
If your source is digital, have you looked at the MiniDSP miniDIGI product? 4 way stereo, digital in and out. I use a very cheap ES9023 Teradak I2S board with mine and it sounds great. I2S outputs can be accessed internally if you can solder reasonable well.
Old 11th January 2016, 10:14 AM   #3
Yeah, I'd looked at the minidigi but perhaps I'd dismissed it too quickly. IIRC it has neither USB nor analogue inputs so it didn't seem suitable for any of my sources.
BUT, yes it would let me replace the DAC from my main digital source with a simple USB/SPDIF (or tosslink) converter, which may be better. I see the minidigi also has two switch-selectable inputs so I could have the DAC connected to the second input for my analogue sources.
I also considered the nanodigi 2x8. I wasn't sure it gained much over the minidsps at the time, since it would need a decent quality 6 or 8 way DAC adding on the outputs. However, thinking again it could have advantages. As above, it would allow a usb/spdif converter on the input instead of unnecessary D/A stage. The need for outboard output DACs would make it more upgradable, and I could even have those DACs positioned at the active speakers, making the long signal runs digital.
Hmm, interesting, much food for thought. Thanks!
Kev
Old 11th January 2016, 10:17 AM   #4
Oops I meant the nanodigi 2x8- that's the one I have. Sorry for the confusion!
Old 11th January 2016, 10:24 AM   #5
No worries. It made me think again and come up with a similar idea, which is good. :-)
Cheers
Kev
Old 11th January 2016, 10:30 AM   #6
You might have already seen it, but they also do an 8 ch I2S DAC now that should work with the nanodigi if you are ok with soldering. https://www.minidsp.com/products/minidspkits/minidac8
Old 11th January 2016, 10:39 AM   #7
Yes, it would be a neat solution, its worryingly cheap for an 8-way but then probably as good as the DACs in a minidsp.
Cheers
Kev
Old 14th January 2016, 12:10 AM   #8
Eldam is offline Eldam  France
Banned
Anyone knowing an equivalent which can be MCLK feeded ! Was it RasBerryPi, PC, or Appliance ?
Old 14th June 2016, 08:09 PM   #9
Loafmeat is offline Loafmeat  Germany
Hello
maybe this solution is intersting for you:
http://www.diyaudio.com/forums/softw...ml#post4745539
Guenter
Old 14th June 2016, 08:36 PM   #10
Kjeldsen is offline Kjeldsen  Denmark
Another sound that is fairly cheap is ESI U46 XL
ESI - U46 XL
MiniDSP is straight forward, PC is versatile
I use MiniDSP 2x4 right now, but I would like to try linear phase, and that I can get for free using my PC and a good soundcard (not free).
What to recomment? - I don't know it depends if you are willing to use some days to learn the PC'way. MiniDSP is up and running in minutes.
http://kjeldsensforbindelser.dk
Mini DSPs or computer + sound cardHide this!Advertise here!
impedance test in Arta - any risk to sound card/computer knifeinthesink Multi-Way 5 16th July 2015 04:56 PM
Can I use an external USB DAC as a totally normal computer sound card? Welcome PC Based 6 7th December 2013 09:34 PM
Sound card for computer audio/testing ted4412wilt Digital Line Level 1 9th February 2009 05:06 AM
Power Amplifier -> Computer Sound Card EchoWars Everything Else 4 21st December 2005 12:08 AM
Copyright ©1999-2017 diyAudio
