24-bit, 192 kHz ADC with PCM4202 and DIT4192/CS8406
Old 21st November 2015, 07:17 PM   #1
Gunders is offline Gunders  Norway
Default 24-bit, 192 kHz ADC with PCM4202 and DIT4192/CS8406
I have started a project where I am going to build an analog-to-digital converter for my record player and amplifier. The ADC will be based on around Texas Instruments PCM4202 24-bit ADC and DIT4192 or CS8406 digital transmitter. I have made a simplified overview of the ADC and will quite soon start with the design and drawing the schematic.
I will certainly have some questions during the design and layout phase, and I start easy with my first one regarding master/slave operation of DIT4192/CS8406. I will set the PCM4202 in Master Mode and I then assume it is right to set DIT4192/CS8406 in Slave Mode. SYNC and SCLK at the DIT4192/CS8406 will then be inputs and receive clock information from PCM4202. I am right in my assumption? Or should DIT4192/CS8406 be put in Slave Mode only when multiple DIT4192/CS8406 are working in parallel where one of them is the master and the rest are slaves.
File Type: pdf ADC_PCM4202-DIT4192-CS8406_overview.pdf (83.4 KB, 112 views)
Old 22nd November 2015, 01:59 AM   #2
twest820 is offline twest820
All that really matters is only one device on the I2S link drives the net; otherwise they contend (and probably eventually one device fries). As you're not locked on a SPDIF transmitter it may be worth considering parts, such as the WM8804 and 8805, which include crystal drivers and some MCLK distribution.
Old 22nd November 2015, 05:36 PM   #3
Thank you for your help. I will go for the ADC as Master and transmitter as Slave.
24-bit, 192 kHz ADC with PCM4202 and DIT4192/CS8406Hide this!Advertise here!
USB powered ADC (pcm4202-cs8406) 00940 Digital Source 4 17th July 2015 01:14 PM
E-MU EMU 1212M 24-bit 192 kHz Audio MIDI Sound Card PCI john65b Swap Meet 0 13th December 2014 09:25 PM
New USB 2.0 192 Khz 24 bit controller chip.... soekris Digital Line Level 25 1st December 2012 10:15 AM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 05:14 PM
