Go Back   Home > Forums > Source & Line > Digital Line Level
Old 10th February 2004, 07:08 AM   #1
rbroer is offline rbroer  Netherlands
rbroer's Avatar
Michael,
I built it a while ago on vero-board, it's quite easy.
IMHO it sounds better than the active I/V posted in the "simple I/V" threads, but not as smooth as the folded cascode. YMMV.
I used just the raw supply for the positive rail, no need for regulator because of the constant current for the LED/diodes references.
Rudolf Broertjes
Old 10th February 2004, 08:02 AM   #2
mihu is offline mihu  Austria
Thank you Rudolf, I´ll try that version. I guess for a TDA1545 I have to replace D5 with a 1N4148, anything else to change? What type of capacitor do you recommend for C1? 100µF is a pretty high value that makes a a "better quality" cap pretty expensive.
How about driving a passive preamp from this stage?
Michael
Old 11th February 2004, 07:33 AM   #3
rbroer's Avatar
Originally posted by Andypairo
how does it compare it with passive I/V?
If I understand correctly the supply is 15V, right?
If I should use a battery for powering it do I risk clipping?
BTW What's the color of the leds?
- read my earlier posts for MY opinions
- I think I used something like raw 18V after the rectifiers
- depends on voltage of battery and value of Riv
- green
- don't think any change needed for TDA1545A, except Riv/Civ
- use whatever cap YOU like. I just used 100u for simulations, 2.2u Audyn KpSn in real life.
- well..., try, and let us know
The intend was to keep it simple, active stage with low parts count, just one rail in stead of two, using raw supply.
For really low parts count, one can even ommit casode transistor in the current sink (Q2, D2) and the common base (Q3, D3) as well.
Rudolf Broertjes
Old 11th February 2004, 08:35 AM   #4
Terry Demol's Avatar
- green
Watch out for OP voltage compliance of DAC, In other words,
what is the optimum DC level for dac OP. Your dac feed in point
is sitting at about +2.7V ? Shouldn't this be 0V?
Terry
Old 11th February 2004, 09:23 AM   #5
Andypairo's Avatar
I use a 12V gel battery.. is this voltage too low?
Cheers
Andrea
Old 11th February 2004, 09:33 AM   #6
rbroer's Avatar
As mentioned earlier, this circuit is intended for TDA1543, (TDA1545A as well) with dac output voltage compliance of 1.8V~ Vsup-1.2V
Rudolf Broertjes
Old 11th February 2004, 10:37 AM   #7
hifi is offline hifi  Sweden
The voltage drop over a led is well defined (because of the single wavelength of the light emitted) so different colour yields different voltage drop.
/micke
Old 11th February 2004, 01:37 PM   #8
Bricolo is offline Bricolo  France
Bricolo's Avatar
what should I change to use it with a TDA1541A?
Old 11th February 2004, 03:01 PM   #9
Andypairo's Avatar
Bricolo, at a first glance what you ask is not trivial.
The emitter of Q4 is at a fixed voltage (2Vled - 0,7V), and you should bring that node to a voltage suitable for the DC compliance of the 1541, which is much smaller as I recall.
However, if you bring the Idac node too low the current sink tied to Gnd can't work anymore, hence a negative supply is needed...
Cheers
Andrea
Old 11th February 2004, 03:48 PM   #10
Bricolo's Avatar
Cheers
Andrea
2*2Vled, no?
BTW, what's the normal voltagr for red and green leds?
I measured the 5mm red ones I had: 1.63V, the 3mm green ones: 1.62V
Opamp for Vref on TDA1543, TDA1545A hollowman Digital Line Level 2 24th August 2009 09:10 AM
30 Watt Class D IC that uses a single rail Maroc7 Class D 4 28th March 2009 02:24 PM
Using split rail supply for single rail DC DanX Chip Amps 1 15th March 2008 05:18 PM
Gainclone single rail PS question KT Chip Amps 11 30th September 2004 06:47 AM
Page generated in 0.11886 seconds (79.57% PHP - 20.43% MySQL) with 11 queries
