ADAU1701 noise floor & dynamic range notes - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 23rd July 2015, 08:11 AM   #1
colossusfan's Avatar
Default ADAU1701 noise floor & dynamic range notes
Having recently plunged into using this DSP for a project after a lifetime of using analogue I am somewhat taken back by its real world performance particularly given the chips specifications. When I first ran this chip I had terrible problems with the internal level meter as displayed by SigmaStudio however using readback in hex of the peak level helps understanding of these blocks, after consulting AD it turns out the ADC has a horribly large DC offset that must be blocked using the DCB function. I used REW to generate test signals to assist in calibrating the beast!!
The internal rms meter does not show levels below -45dB so the method I used was the peak capture block and noting the levels in hex, these can then be converted to decimal and ratio's turned directly into dB. Using this method and checking the output for distortion it was possible to establish the saturation signal level of the ADC and this is about +1dB and peak 8,0,0
With the inputs shorted the peak became 0,0,20 hex giving a noise floor of -84dB........this is way higher than I am used to in the analogue world, not a showstopper as my project is a sub controller BUT at this time I would not consider it for much else!! This level was later confirmed using REW to measure it after calibration.
Please note the measurements are independent of the PC audio path BUT they do depend on the USB connection so performance may improve when there is no USB connection (my project has yet to reach the stage where I can safely cast the DSP adrift into standalone).
Hope this helps anybody considering this chip, otherwise it does what it says on the tin, I had to build my own boards and programming gear as like most of its fellows the development kits are extortionately expensive for most folks!!
Old 23rd July 2015, 09:11 AM   #2
Elektor Electronics and FreeDSP designs (boards) are not expensive, but I think we need a brand new ADAU1701 board with separate ADC chip (PCM1804 or PCM1803A if unbalanced input is enough) and an extra DAC. A DAC chip like the TDA1387T would be fine for an extra channel pair for (sub)woofers.
Tube Signal to Noise Ratio / Dynamic Range DualTriode Tubes / Valves 10 26th April 2012 08:17 PM
Output noise of PGA2310 or PGA2311 or PGA4311 (for dynamic range) behnam Chip Amps 2 26th January 2012 10:42 AM
Low Distortion High Dynamic Range Pre-amp Nico Ras Pass Labs 64 18th May 2007 05:26 AM
SNR/Dynamic range worsens in low frequency range. percy Digital Source 3 1st June 2006 12:41 PM
Dynamic range compression & FPGA marco72 Digital Source 2 24th March 2006 10:55 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
