Cambridge audio D500se static popping noise on one channel - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 13th July 2015, 09:38 AM   #1
Default Cambridge audio D500se static popping noise on one channel
Hi
Can anyone help?
My Cambridge Audio D500se makes a static popping noise on one of the channels, the other is fine.
What is the likely cause?
Regards.
Michael
Old 4th August 2015, 08:44 AM   #2
No ideas?
Could this be a problem with the laser pick-up.
Regards.
Michael
Old 8th August 2015, 03:13 AM   #3
Just got a D500SE on my bench, first time. Judging by the parts used, the #1 most likely cause for popping in a channel would be failing electrolytic caps, as they used very crappy brands. 2nd most likely is simply a bad NE5532 opamp chip. 3rd & almost certainly only other possibility is a bad channel in the CS4391 dac chip.
Absolutely can not be a laser issue. That would always affect both channels.
Old 8th August 2015, 07:17 PM   #4
Hi Stephen
Thanks for your reply.
Please could you suggest which caps to replace, and with what?
I am not sure about the general rules about upgrading/replacing caps. I know that the voltage needs to be the same or higher. What about the capacitance?
I have found 5x NE5532 in my spares box, but they are NE5532P and the ones in the CDP are NE5532N. Problem? I can soon buy some more.
Regards.
Michael
Cambridge audio D500se static popping noise on one channel dublin78 Digital Source 0 7th July 2015 09:58 AM
cambridge audio d500se schematic gari Digital Source 5 20th January 2012 05:15 PM
Please help me add a Tentlabs clock to Cambridge Audio D500se dublin78 Digital Source 0 20th January 2012 10:49 AM
Speakers popping and static noise at all volume levels PPI Amp duderino201 Car Audio 21 8th May 2010 09:19 PM
popping and static noise in an Altec 1592A lassoharp Solid State 7 14th March 2009 02:25 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
