SU0 xmos u8 dac + AK4490 questions
Old 13th November 2017, 08:43 PM   #41
jussik is offline jussik  Finland
Thanks, for now I just stuffed one between the case and the regulators and there is just a little contact to the case. I'll try a better solution at some point.
The case seems to be now at 30C (~20C ambient) when it is running and the first regulator at 60C (based on my Flir One), with the USB side end of the case missing. If these are correct readings I should probably be ok.
Taking the same measurements without the pads in place might be the next phase in figuring out if they are necessary or useful in their current use.
Old 5th December 2017, 06:18 AM   #42
paddington is offline paddington
Originally Posted by 24century View Post
Also my dac (XMOS U8 + 4490eq) went malfunctioning constantly after 10-20 mins playing, sound output just stopped after a click sound and foobar stopped as well (stuck), replaced the power regulator LM7805 and 7905 also added a heatsink doesn't really help and make sure it properly grounded with the metal cover.
After unplug the power and USB cord it will resume that will be the only solution.
Don't think it is a power problem since power output and amp section still functioning alright, no clue! seller can be provide a schematic or PCB drawing
Any idea or suggestion?
Hi all, I just bought this DAC and I have the same issue as 24century. I've tried a different USB cable, using my laptop, desktop, and phone as the source, uninstalling and reinstalling drivers, and trying all the different USB ports and nothing has worked. When the audio cuts out on the computer, the computer still recognizes that the DAC is plugged in. In order to get sound again, I have to turn the DAC on and off. Can anybody help me fix this? At this point I'm also willing to break it open and take a soldering iron to it if anyone thinks it's a hardware problem and can give me instructions.
Old 8th December 2017, 07:27 PM   #43
ferossan is offline ferossan  Chile
Did you try using a Mac or Linux machine? Looks like a Windows driver problem.
Old 15th December 2017, 08:48 AM   #44
I don't have access to a mac or linux machine. I have tried it on my android phone though and it has the same problem. In terms of drivers, I've tried the stock windows drivers and some xmos drivers (v3.34) I found by googling. Neither seem to help.
Old 29th December 2017, 10:57 PM   #45
24century is offline 24century
Send a message via ICQ to 24century SU0 xmos u8 dac + AK4490 questions
Were you using the headset output or line out to an external amp?
Old 13th January 2018, 08:12 AM   #46
I've been using the headset output but I did try the line out to an out for a bit. Audio still cuts out when trying both. Another thing I've noticed so far is that it cuts out a lot more when connected to my desktop. When I connect it to my laptop it only cuts out two or three times before it stays on. This kind of makes me think it may be a software issue again, but I have no idea where to start with that.
Old 13th January 2018, 09:15 AM   #47
DRONE7 is offline DRONE7  New Zealand
I am guessing it is a power supply issue if the device is still recognised.
Xmos U8 is usually powered from the desktop/laptop via usb so you could try this fix.... It worked for me with an xmos U8 and Ess sabre dac. I just used a usb hub as the power source as a quick fix while I build a linear supply.
[DIY] TNT 221 USB Y-cable [English]
Old 16th January 2018, 12:29 AM   #48
I just tried out a different ac adapter but that didn't help. If I try this usb mod, will the dac know to draw power through the usb port instead of through the DC input port?
Old 20th January 2018, 05:59 PM   #49
loandmot is offline loandmot
Hello,
I'm looking at this DAC too, and could buy it with no risk, at 40€ the board.
But I don't have any other DAC (I used FDA before), and wouldn't be able to compare.
Does it sound good?
Are there some components that could be change to improve it?
I would apreciate if somme peaple who already have it take me their opinion...
Laurent
Old 8th February 2018, 12:02 AM   #50
Originally Posted by loandmot View Post
Hello,
I'm looking at this DAC too, and could buy it with no risk, at 40 the board.
Does it sound good?
Laurent
It sounds pretty good for the amount you pay, bought 2 sets two years ago and it sounds amazing back in the day
I increase the input power to 20V and improvement shows.
Op-Amp can be replaced easily and it improves, but this board can only be operated in parallel mode that"s the dark part.
SU0 xmos u8 dac + AK4490 questionsHide this!Advertise here!
AK4490 USB Dac with dsd support. sonnya Vendor's Bazaar 1562 5th June 2018 03:36 AM
DAC AK4399 + XMOS on Ebay luckyluke198x Digital Source 30 22nd February 2016 06:15 PM
YJ Xmos U8 + Wm8741 + Ad827 paolo66 Digital Source 0 15th April 2015 02:17 PM
MiniDSP USBStreamer + DIYINHK AK4490 dac multichannel SL06 Digital Line Level 4 3rd March 2015 09:53 AM
XMOS/PCM5102a DAC vs Modded CD63 - New DAC loses - Why? dwjames Digital Source 4 18th January 2014 07:03 AM
