Hypex DLCP - standby mode - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 12th June 2015, 05:38 AM   #1
Default Hypex DLCP - standby mode
Hi there,
I have Hypex DLCP board and are unable to switch this to standby mode. If I would to switch to standby mode, I should apply and external DC voltage (6,5-12V) to connector J17 pins 1 and 2 (it is written in the datasheed). I did this but DLCP is still on. Has anybody the same problem?
I found in Manual....you have to apply external DC voltage to J17 and to have Controll board. Does it mean that if i use DLCP without control board. I will be not able to have standby mode? I dont believe it. Can anybody who have this DLCP do some test if he is able to switch the DLCP into the standby mode without Control board by appliing voltage 3-12V on pin J17 ???
Hypex NC1200, DLCP, Ian FIFO, WaveIO, Neotech wire, Xhadow+Mundorf con, Lundahl choke edbk Swap Meet 30 24th June 2015 12:40 PM
FS: Sitronik Amps, Hypex DLCP, Thel Power Supplys Guitarfreak Swap Meet 5 12th February 2015 01:53 AM
SMPS400 standby mode ? r100 Class D 6 21st December 2013 08:20 PM
FS: Hypex DLCP and input board mcai7et2 Swap Meet 1 5th November 2013 05:11 PM
need LM1876 mute mode and standby mode help JozzaG Chip Amps 21 19th January 2012 05:28 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
