The Best DAC is no DAC
Old 6th November 2017, 11:35 AM   #1851
Presley is offline Presley
Originally Posted by MarcelvdG View Post
There are small switched mode regulators with switching frequencies in the MHz range, so it should be feasible. You still have the issue that you need to keep reference (= supply) very clean, though.
can you post a link of these regulators?
supply could be batteries?
Old 6th November 2017, 11:41 AM   #1852
ionutzxpo is online now ionutzxpo  Romania
Send a message via Yahoo to ionutzxpo
hi, and the reference voltage can be kept very very clean by a capacitance multiplier!
Iacob Ionut
Old 6th November 2017, 07:12 PM   #1853
would a supercap come in handy here?
Old 6th November 2017, 08:01 PM   #1854
MarcelvdG is offline MarcelvdG  Netherlands
I'm not sure if this helps, but see for example:
LTC3646/LTC3646-1 - 40V, 1A Synchronous Step-Down Converter - Linear Technology
LTC3861 - Dual, Multiphase Step-Down Voltage Mode DC/DC Controller with Accurate Current Sharing - Linear Technology
LTC3839 - Fast, Accurate, 2-Phase, Single-Output Step-Down DC/DC Controller with Differential Output Sensing - Linear Technology
LTC3838 - Dual, Fast, Accurate Step- Down DC/DC Controller with Differential Output Sensing - Linear Technology
If I were to try it, I would use a very well regulated supply, with the feedback sense point of the regulator right at the power stage, using a board with power and ground planes and with large ceramic decoupling caps right next to the power stage. No idea how good or how bad the performance would become, though. I only know that keeping the supply clean despite of the large switching currents drawn from it is quite critical.
Old 7th November 2017, 01:13 PM   #1855
thank you for the links and insights. if i read the data correctly it would easily make a few watts amp and it could be even powered by a 12v agm car battery
Old 10th November 2017, 06:48 PM   #1856
I just noticed this thread:
DSD Playback system, DSF Player + USB DDC + DSD Amplifier
It looks like they are doing what you are considering to do.
Old 11th November 2017, 08:16 PM   #1857
interesting! thanks for the hint. it looks like they want to use two mosfets for performance (high power)
i wonder if those LTC regulators posted above are capable of audio quality. it would be simpler to use those and good enough for sensitive drivers
Old 16th November 2017, 10:50 AM   #1858
Peter Sheehy is offline Peter Sheehy  Australia
Ive have really enjoyed this thread especially the positive approach of the main contributors - congratulations!!
I have just made it thru the 185 pages - WHAT A MARATHON
I left the thread after half a dozen or so pages to give it a go.
Just grabbed a basic DIYINHK XMOS usb board and connected it to an el cheapo Di transformer set I had made to couple phones and tablets to my HiFi system (following the advice from my son- low impedance drives to transformers really make them sing)
Any how I was blown away by the audio sound quality achieved by driving DSD directly into a transformer
No evidence of core saturating with 1.65V DC across 10kohm primary
For those interested it was a $10.00 transformer purchased from Altronics in Oz
Cya Peter
Old 20th November 2017, 04:48 PM   #1859
marconi118 is offline marconi118  Germany
what trafo do you used?
Old 21st November 2017, 05:44 PM   #1860
sergiu2009 is offline sergiu2009  Romania
sergiu2009's Avatar
Cya Peter
Hi Peter,
Glad to hear another positive feedback.
Wich one from Altronics bellow:
http://www.altronics.com.au/transformers/audio-transformers/&gws_rd=cr&dcr=0&ei=rnEUWurKLoSAafyVsbAH]Transformers | Audio - Altronics[/url]
I need to find the original trafo used here (wich is very hard to find) or a cheaper obtainable one.
Thanks in advance.
Ps: tank you all for you advices, i buyed instead of an intel nuc, an micro itx mobo full packed for multimedia + an amd 4890k+ 16gb ram at 2400mhz for this project. Still need to buy next year a pico itx adapter + power brick.
The Best DAC is no DACHide this!Advertise here!
CS8416+CS4398 DAC Kit Support USB + coaxial DAC Board bleachershane Digital Line Level 4 2nd February 2015 09:45 PM
The DAC "do you have experience with this dac", Best diy dac for the money? murphythecat8 Construction Tips 9 17th March 2014 07:30 AM
WTB V2.6 PCB for ES9023 / WM8804 S/PDIF DAC –SUBBU DAC grufti Swap Meet 0 26th November 2012 05:51 PM
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! sharpi31 Digital Line Level 2 10th January 2011 07:03 AM
diyclub.biz DAC-38, DAC-60, DAC-68. Anybody heard? TonyDasilva Digital Line Level 21 13th April 2009 05:10 PM
