passive unbalancing differential signal - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 29th March 2015, 04:07 PM   #1
donovas is online now donovas  South Korea
Default passive unbalancing differential signal
hello. can i unbalance +/- signal from dac with no transformer, no opamp?
i'm saying just capacitors from +/- to RCA +/- and pulldown resistor to ground. possible?
Old 29th March 2015, 04:09 PM   #2
merlin el mago's Avatar
Simply a switch to connect - signal to ground for unbalanced signal.
Old 29th March 2015, 04:57 PM   #3
so no cap needed for - signal?
Old 29th March 2015, 05:00 PM   #4
DF96 is offline DF96  England
The output of a DAC probably isn't balanced but biphase. A balanced output you can convert to unbalanced just by grounding one side. A biphase output you convert to unbalanced by totally ignoring one side.
Old 29th March 2015, 05:35 PM   #5
This may not be the whole story.
Please measure whether the signal is riding on top of a DC voltage (perhaps a couple of volts). This needs to be eliminated either with a cap or sending both legs to a transformer so the DC (+ and -) will cancel.
Old 29th March 2015, 05:52 PM   #6
yes, both output have dc offset. 0.3v or so.
Old 29th March 2015, 06:05 PM   #7
That does not make sense, I may be missing something.
We are trying to see if signal is balanced (one side inverted relative to the other). Or is it bi-phasic ie. one side riding on (+) DC and the other side riding on (-) DC. In my limited experience, the DC would be much larger than 0.3V
Old 29th March 2015, 07:14 PM   #8
they are balance, signal polarity +/-. but class a opamp i/v, so dc offset.
custom breadboard dac.
Old 30th March 2015, 10:34 AM   #9
Probably biphase AC, but both riding on approximately equal DC biases. If so, put a coupling capacitor from one output to the RCA inner. Ground RCA outer (at the appropriate circuit point). Put a high value resistor across the RCA to act as a ground leak.
Why anyone should go to the trouble of making/buying a balanced DAC then running it unbalanced is a question for another day.
Old 30th March 2015, 11:39 AM   #10
thank you.
as for the big question, sound still benefit from unbalancing than using one phase.
Tube conversion of differential to single ended signal audiowize Tubes / Valves 5 8th August 2013 09:19 PM
passive differential input stage Bernhard Solid State 1 29th January 2013 04:12 PM
Floating Differential Signal Zaaphod Analog Line Level 34 27th September 2011 10:36 PM
Volume control of a differential signal berni8k Digital Line Level 20 26th August 2009 10:43 AM
Creating a differential signal from a single-ended signal for bridged amps Peter Daniel Chip Amps 45 8th November 2004 01:47 PM
Copyright 1999-2017 diyAudio
