Tda1541 - volt problems
Old 20th March 2015, 10:17 PM   #1
Green77 is offline Green77  Sweden
Default Tda1541 - volt problems
Hi all!
Just finished a own pcb for this dac chip.
When the td1541 is not in the sockel i can trim in +5 v, -5v and -15v,
But when i put the tda chip in +5v is ok. But -5 and -15 drops to -2 and -6 volt...
Cant find the problem. Anyone?
Best Regards //Daniel
Old 20th March 2015, 10:26 PM   #2
RS232 is offline RS232  United Kingdom
Can you post schematic ?
Is the TDA1541 an original ?
More information please
Ric
Old 20th March 2015, 10:55 PM   #3
Sorry, i haven't the possiblity to scan it tonight.
It feed from diods and caps to two lm337 for each - volt.
When power is off i get "beep" to pin to on lm337. That is ok.
But when power is on i get beep to ground on pin 1,2 and 3..
I cant find it...getting mad!
Old 21st March 2015, 02:48 PM   #4
You probably have a fake 1541
Where did you get it from ?
Old 21st March 2015, 03:14 PM   #5
Hello.
No, i have 2 diffrent. Both working in my eBay pcb dac.
I tried to disconnect -5v but -15 still dropped to -6v. And if i disconnect -15v the -5 still drops to -2...
I tried to feed the tda1541 directly from lm337 with wires but voltage dropped.
Without the dac chip in place i can adjust just fine.
Regards //Daniel
Old 21st March 2015, 05:48 PM   #6
poynton is offline poynton  United Kingdom
poynton's Avatar
What is the input voltage ?
Have you connected the LM337s correctly ?
Are the LM337s the correct amperage rating ?
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 21st March 2015, 05:55 PM   #7
Hello
Input volt is 22 volt on both from same set of diods/caps.
Both 337 is to-220 1amp.
Pin 1 adj
Pin 2 input
Pin 3 out
Old 22nd March 2015, 12:12 PM   #8
Hello
Here is the scematic:
Very basic. When the TDA1541 not is installed everything works and i can adjust.
When it's installed i can stil adjust but the voltage dropped to -2 and -6 volt (max).
Here is the pcb:
Some parts are SMD under the card (TL431 and some caps/resistors)
Yesterday i bended pin 15 and 26 on the TDA1541 out of the sockel, liftet L3 and L6 and solder wires directly to the pins between them. Didn't work, still the voltage dropped.
Could it be something after the TDA1541 that is wrong? Because it works when the chip is not installed...
Best regards//Daniel
Old 22nd March 2015, 06:23 PM   #9
Ben Mah is offline Ben Mah  Canada
Have you checked the power supplies (-5v, -15v) with test loads?
According to the tda1541a data sheet, the -5v current demand is about 50mA and the -15v current demand is about 35mA. For the -5v supply, a 5v/.050A=100 ohm test load resistor, power is 5v x .050A=.25W, so a 2 watt resistor should be more than adequate. Similar calculations for the -15v supply.
The drop in voltage under load is a sign of too much current draw or your power supply cannot meet the current demand. You should test the power supplies with dummy resistor loads before using them to power your dac chip.
What is the voltage before the LM337, and after the LM337? The voltage before should be a few volts higher than the voltage after and the voltage after should be higher than the design output voltage. The 10 ohm resistor between the LM337 and the Tl431 looks a bit small. That resistor is used to drop the voltage between the LM337 and the TL431.
All voltages should be taken with the test loads in place. If you get the same low voltages with the test loads, then there are problems with your power supply.
Old 22nd March 2015, 06:46 PM   #10
If the power supplies check out with test loads (without the dac chip installed), then there may be something wrong on your board or your dac chip, but if you have tested the chips out on another board, then it is something on your board. Check your components for proper placement, polarity, etc, and check your solder joints for cold joints and unintended bridging/shorts.
Has this particular board been used successfully by others?
Tda1541 - volt problemsHide this!Advertise here!
CS812 and TDA1541 problems.. Green77 Digital Line Level 4 10th February 2015 05:52 PM
12 volt to 300 volt inverter question for tubes yourownfree Tubes / Valves 93 30th March 2014 04:41 PM
Help converting 13.5 volt ac to 20 volt majod Power Supplies 2 18th December 2013 06:41 AM
Switching 230 Volt Transformer to 120 Volt OMNIFEX Parts 10 6th April 2008 05:34 PM
Problems with piggy backed TDA1541 Dr.H Digital Source 2 24th May 2002 08:30 AM
Copyright ©1999-2017 diyAudio
