LPF with differential input - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 6th March 2015, 04:08 PM   #1
Toshen is offline Toshen  Ukraine
Default LPF with differential input
Hi. Can anybody tell me how to design LPF that has differential input?
There is Sallen-Key topology for example with one OP. Are both of signals will flow into this OP or there is additional OP is needed(comparer)?
Old 6th March 2015, 04:16 PM   #2
rayma is offline rayma  United States
Originally Posted by Toshen View Post
Hi. Can anybody tell me how to design LPF that has differential input? There is Sallen-Key topology
A balanced input/balanced output version of this circuit would have a second identical circuit,
with the Z4 components connected together instead of being grounded.
If you want a single ended output, connect the balanced outputs to a diff amp circuit.
Old 6th March 2015, 05:18 PM   #3
Did you mean something like this for the second case?
PS. not Vin, means Vout(right cannel +-)
Old 6th March 2015, 05:22 PM   #4
Yes, that looks ok. The impedances connecting the two circuits (R4 and R8) can be combined into just one part.
This will likely be a capacitor (of half the value for a single circuit, since they're in series) for a LPF.
Old 6th March 2015, 05:26 PM   #5
Thanks a lot!
Old 9th March 2015, 07:44 PM   #6
When you combine Z4, you need to double resistors and inductors, halve capacitors that are part of Z4.
You don't have to take Z4 to the other half though, you can leave them to ground.
Tyler
My differential input 49830 Phil Olson Solid State 6 6th May 2012 11:38 PM
Adding a third input to a differential input stage? maudio Solid State 15 11th October 2006 02:16 AM
please advise.. ext. LPF summing differential outputs by an opamp ASSaBeong Digital Source 0 17th May 2006 11:15 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
