ES9018 Audio transformer output stage - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 24th February 2015, 02:08 PM   #1
Default ES9018 Audio transformer output stage
I have 2 different pair of audio transformers to use for... maybe also for es9018 dac.
Which one will be better to use it with es9018 dac. How should i connect it or right filtering, grounding .... for the best result.
Transformers are from Italian audio products GALACTRON.
The first pair is as on picture 90ohm in .... 105ohm out
and second 50ohm in ...25 ohm out or vice versa
I know that some members has good results with audio transformers.Thanks for any suggestion.
Old 25th February 2015, 11:58 AM   #2
Eldam is offline Eldam  France
Hi
You should read the little white paper on Lhundall web site about set up an output traffo with RC filter on it !
Old 25th February 2015, 05:52 PM   #3
I have tried that schematic.
Output pin 2 &3 was 3,2V peak to peak. But distortion and oscillation was huge on scope.
Output 1&2 and 3&4 was quite clean and 1,6V peak to peak.
Connecting ES9018 Agnd direct to pin 10-5 brings no improvement just output is 2,8V peak to peak, output still oscillated.
Connecting disconnecting shield brings nothing.
Any ideas how to improve that schematic
Old 25th February 2015, 07:56 PM   #4
Coil resistance is not enough info. You have to know the turns ratio and the inductance, otherwise it is trial and error.
Old 25th February 2015, 08:24 PM   #5
Where for example LL1684 - do you have those parameters described in pdf?
This transformers are taken out from amplifier where xlr was transformed to rca...
Coppied from manual....
*In addition, the output stage is built with two transformer amplifiers with a 1:1 ratio with the core "C" and a bandwidth of 10Hz to 100KHz + - 0.5 dB.
The transformer-balanced input, in addition to four RCA line inputs, gives the end user the ability to use multiple devices and manage their connections differently...
I will measure inductance in next days.
Old 26th February 2015, 12:45 AM   #6
Hi Androa,
Try to discover, is the transformer made
for V-out dac's or I-out dac's.
This is for the impedance adjustment.
More info on sowter.com.
Old 26th February 2015, 01:18 AM   #7
Do a search on the Twisted Pear section of this forum and there is a thread on the B II with transformers. The B II dac uses the ESS chip. Lots of info.
Buffalo II & transformers
Edit Done the search for you.
Old 26th February 2015, 08:20 AM   #8
Thank you.
Have already checked... But miss mesurements...all are saying just how good sound is.
When I listen ...sound is ok...but scope ....no good. I don*t like to listen to distortions although they can be nice for ears.
Old 26th February 2015, 09:43 AM   #9
Done. Scope is clean. Did you give any filter on input or output of transformer?
Old 26th February 2015, 12:09 PM   #10
Read about the "Rasmussen Effect" which is covered in one of the threads on the ESS dac. I actually don't use any filter. Just let the transformer, interconnect etc do the work...
David
Transformer-driven SEPP output stage. Circlotron Solid State 17 20th February 2015 04:22 PM
transformer for dac output stage Salsero Digital Source 7 6th December 2009 04:22 AM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 11:18 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 07:15 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
