Filter brewing for the Soekris R2R - Page 33 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 6th March 2015, 08:58 PM   #321
oneoclock's Avatar
Originally Posted by spzzzzkt View Post
These are done using the impulse test function of Fuzzmeasure?
What are the traces in the HD charts? Frequency response is fairly obvious but what about the two around -100dB range?
Apologies. Is second to 10 Khz and third harmonics up to 8 kHz. Yes Fuzzmeasure program. Measures has made after having several hours on. And for every picture I made a 5-6 measures 3 logsweep 10 seconds each to check out always see similar.
Old 6th March 2015, 09:00 PM   #322
TNT is offline TNT  Sweden
Dotted is 3:rd, solid 2:nd.
MB2 doesn't hold what it promised. Either the design was not OK or the DAM could not recreated it. Seems like the former.
Old 6th March 2015, 09:03 PM   #323
Thanks for the measurements. What "sound card" did you use. Is it via the buffered or unbuffered output?
Old 6th March 2015, 09:09 PM   #324
oneoclock's Avatar
Buffered output.
Old 6th March 2015, 09:15 PM   #325
These are very interesting results. Thank you for taking the to test and collate them.
Old 6th March 2015, 09:16 PM   #326
Buffered output.
Balanced?
Balanced should have slightly lower levels of 2nd harmonics than unbalanced.
Old 6th March 2015, 09:41 PM   #327
Could you provide me wav of those signals?
The test signals are generated using SignalSuite: SignalSuite Details
Under periodic signals tab: 3000Hz, 100% amplitude for signal and output, and I/O calibration set to FS=1.
Old 6th March 2015, 11:27 PM   #328
oneoclock's Avatar
Buffered output. And Balanced.
Old 7th March 2015, 12:04 AM   #329
Question Thanks
Measurements made to DAM1021 DAC with Motu Ultralite MK3. Fuzzmeasure program.
Thank you so much oneoclock! At least some real measurements of frequency and impulse response of this DAC.
Now why NOS has less than perfect impulse response with both pre and post ringing present?
spzzzzkt: please no tire (tyre in your world) taunt this time.
Old 7th March 2015, 07:20 AM   #330
Now why NOS has less than perfect impulse response with both pre and post ringing present:
Real measurements need an adc....which has a filter...
Soekris 's DAC implementations Eldam Digital Line Level 972 14th January 2017 06:31 PM
Sold: Soekris DAM1021 R2R DAC Eldam Swap Meet 6 6th February 2015 08:23 AM
24-bit R2R DAC using miltiple 16/18/20-bit R2R chips Marek Digital Source 21 1st April 2011 10:05 PM
project brewing in my head, challenging, but seem like a good way to try new concepts lemans23 Multi-Way 26 11th October 2005 01:29 PM
Copyright 1999-2017 diyAudio
