Filter brewing for the Soekris R2R
Old 21st February 2015, 11:46 AM   #141
leehan is offline leehan  United Kingdom
Originally Posted by lehmanhill View Post
Leehan, please document the filter.
rePhase file attached.
Used a low noise floor windowing and adjusted centering for IP as suggested by Pos, otherwise nothing special.
EDIT: Also used same roll off values for LP and MP.
IP filter you mentioned has similar tradeoff (higher stopband floor). I hope somebody actually tests this for image attenuation and other criteria. I don't have any means to do so and time to set up one at the moment.
I'm testing the filter with mostly small band acoustic and electric music with plenty of acoustic or electric bass, drummers using cymbals a lot, clean guitars, female vocals, brass instruments, piano and electric keyboards and synths. Not tested with heavy guitars yet. And still too much albums to listen for a final verdict...
Of course, this verdict will be for my system and ears Very excited that people are sharing and testing these.
Cheers.
Old 21st February 2015, 01:45 PM   #142
MisterRogers is offline MisterRogers  United States
Can you say Audio?
I'll chime in; I'm finding MB2b very pleasant.
Old 21st February 2015, 02:29 PM   #143
Originally Posted by TNT View Post
Wating for your assesment of MB2b.
Strangely my dac doesn't lock with MB2b.skr...?
"Assessment" is an overstatement
Old 21st February 2015, 03:22 PM   #144
soekris is offline soekris  Denmark
Interesting, as:
MB2b: dam1021,44100,2,1,1016,1
is not a valid option. Maybe it result in something close to non oversampled, but I have no clue....
S๘ren
Old 21st February 2015, 03:31 PM   #145
TNT is offline TNT  Sweden
I was aiming for 2x oversampling - ok?
How would I achive this?
What are the valid options for these params?
Old 21st February 2015, 03:41 PM   #146
Can you say Audio?
Yes - very interesting.
Old 21st February 2015, 03:47 PM   #147
zfe is offline zfe
What do you consider as 2x oversampling here, 1 -> 11110000?
If yes, convolute your filer, with the filter having four times 1 as taps and stay formally with 8 x oversampling.
Old 21st February 2015, 04:07 PM   #148
Default Why IP for 44kHz sources.
OK, a post explaining my interest in IP filters. Statements are based on scientific claims. They may help somebody beginning their journey on this thread. My conclusion may be BS.
1. We distinguish timbre of different instruments mainly by "attack" of the sound envelope. Daniel Levitin mentions (1) a research where test subjects had difficulty distinguishing piano from guitar when attack portion of the sound was removed. Too long pre-ringing may affect attack of the envelope negatively. This eliminates maximum phase filters and warns about linear phase (LP).
2. We are more sensitive to pre-masking than post-masking in a phenomenon called temporal masking (2). This means we can tolerate more post-ringing than pre-ringing. This gives minimum phase (MP) and advantage over LP.
3. Duration of ringing is affected by the steepness of the roll-off curve. Longer durations affect items 1 and 2, and also transients negatively (3). A slow-roll off is desirable for shorter ringing. But as everybody knows DA artifacts also need to be attenuated. By how much? This should depend on person's hearing and listening environment (headphones, speakers, acoustic treatment, etc.). Although there should be a limit to this since we share the same evolutionary hearing system. Also manufacturers that adverise use of slow roll off filters are likely to deal with this after the dac by other means. We don't have them on dam1021, so we need to deal with this by filters. This implies using filters with steep-ish roll off and with low stopband floor. Unfortunately, too much post-ringing caused by this type filters may also render MP only filter undesirable.
4. We are trying to get best out of 44.1kHz sources. This will always be a compromise. There are many publications about benefits of high sample rate (both processing and hearing wise). I have to settle on a filter and move on.
5. [Non-scientific] Different types of filters said to perform better for different types of music and recording environment. My personal interest is to settle on one that is true to the timbre of instruments as much as possible, then transients, and finally headphone listening.
Hence my preference of IP for 44.1kHz as an optimisation between pre and post ringing given the necessary roll-off steepness. I also found the phase related experiment I mentioned earlier useful.
For the IP filter I'm using at the moment, I will try to bring down the stopband floor lower to at least -80dB at Nyquist while keeping ringing around 1ms.
Cheers.
PS: When configuring a filter for higher sample rates than 44.1kHz, is it just a matter of using correct number of taps Soren stated? Do we need any other adjustment to the filter itself? Thanks.
(1): Daniel J. Levitin, This is Your Brain on Music: Understanding a Human Obsession
(2): Auditory masking - Wikipedia, the free encyclopedia
(3): Music and the Human Ear
Old 21st February 2015, 04:39 PM   #149
No but 1->10 as it works with 0 instertions - and 88khz. But what S๖ren say, it seems undefined
I wonder in which dimension?
Old 21st February 2015, 04:42 PM   #150
Eldam is offline Eldam  France
Banned
Maybe some info to pick here about digital filters ?
I don't like too much this webzine think it's biased, but mostly here in this review the Chord engineer is talking about him HUGOTT DAC and some choice about digital filters strategy : too complicate for me ! Maybe could help, dunno ! 6moons audioreviews: Chord Hugo TT
Filter brewing for the Soekris R2RHide this!Advertise here!
Soekris' DAC implementations Eldam Digital Line Level 1069 11th April 2018 04:18 PM
Sold: Soekris DAM1021 R2R DAC Eldam Swap Meet 6 6th February 2015 07:23 AM
24-bit R2R DAC using miltiple 16/18/20-bit R2R chips Marek Digital Source 21 1st April 2011 09:05 PM
project brewing in my head, challenging, but seem like a good way to try new concepts lemans23 Multi-Way 26 11th October 2005 12:29 PM
