Filter brewing for the Soekris R2R - Page 135 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 20th December 2016, 06:59 PM   #1341
levelUP is offline levelUP  Lithuania
Hello, everyone.
I would like to share my experience with dam1021 dac's
currently comparing dam1021 fully balanced version mixed filter with PCM1704 x 4chips in nos mode, sowter transformers. Everything feeds on A123 batteries. Without voltage regulators as possible. Usb interfaces: waveIO 3,3V battery modded / m2tech OEM / singxer F1 battery modded ( F1 is the best, then m2tech, then waveio).
It little bit winning in dynamic over PCM1704, but completely loosing in speed/ resolution. I was hoping for better performance from dam dac.
Old 21st December 2016, 11:54 AM   #1342
oneoclock's Avatar
This is corrected.
1021filt.1.6.zip
Old 21st December 2016, 01:47 PM   #1343
Originally Posted by levelUP View Post
Hello, everyone.
It is not necessary to run the batteries without regulator/chargers for best sound.
How long are the voltages staying constant while playing music? Are you using the onboard regs of the SOEKRIS using the batteries to power the onboard regulators? If this is the case your are missing most of the advantages of battery power.
Is the DAC you are comparing to using the same basic powering scheme as what you have used for the SOEKRIS?
Most people condemn the SOEKRIS for having less than stellar dynamics. I have not been bothered by this but it does stand out in your assessment.
Rick McInnis
Old 21st December 2016, 10:39 PM   #1344
voltages staying constant 3.2V ~ 8 hrs with 4 cells ( 2X dacs) it's better to remove all unused opamps, regulators as they consume power.
Old 21st December 2016, 11:36 PM   #1345
soekris is offline soekris  Denmark
How do you get -4V from a LT3042 ??
The reason to the distortion at -3.2V only is the jfets, their gate-drain diodes start to conduct without the higher off voltage to the gates. Or you could just remove the jfets, but then you get the turnoff thumps.... Or connect -6.4V to J2 pin 9 instead of -3.2V.
The onboard vref regulators are better then an external LT3042, but then, 6.4V will kill an opa365.... If you insists then ensure your regulators are very close to the dam1021 and connected with thick wires.... You might want to verify than vref ripple is less than 1mV pp.
You might want to use the "soft" filter settings, sounds like it will more to your liking....
Since your're using the unbuffered outputs you need to keep the wires reasonable short, in balanced mode the Zout is 1280 ohm.
And btw, your postings really belong in the main dam1021 thread....
Søren
Old 27th December 2016, 03:01 AM   #1346
Originally Posted by oneoclock View Post
This is corrected.
Attachment 587039
Yes, it's working now.
Thank you very much
Old 11th January 2017, 11:26 AM   #1347
with ~40K resistor Rset
Also it's working possible to get 1,2V
Old 11th January 2017, 03:20 PM   #1348
No, how do you get negative voltage from a positive voltage regulator ??
Søren
Old 11th January 2017, 04:43 PM   #1349
batteries should be without center tap Click the image to open in full size.
but the scheme become little bit complex, it's easier with 3,2V instead of 4V
Old 11th January 2017, 05:08 PM   #1350
keantoken's Avatar
Yep, it works as long as the voltage sources are isolated.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Soekris 's DAC implementations Eldam Digital Line Level 1039 31st May 2017 11:23 AM
Sold: Soekris DAM1021 R2R DAC Eldam Swap Meet 6 6th February 2015 07:23 AM
24-bit R2R DAC using miltiple 16/18/20-bit R2R chips Marek Digital Source 21 1st April 2011 09:05 PM
project brewing in my head, challenging, but seem like a good way to try new concepts lemans23 Multi-Way 26 11th October 2005 12:29 PM
Copyright ©1999-2017 diyAudio
