Hello!
I haven’t updated my DAM1021 for a long time, I have installed firmware 1.06 and filters from #1352 (oneoclock).
What is the most interesting filters set now?
Thank!
Thank!
TNT, would you mind posting frequency and impulse response graphs for you filters in posts 1633 and 1833?
Are there similar graphices for the 128DP filter?
Also, someone did THD simulations or measurements with different filters, has anyone done comparisons in this regard for the more recent favourites?
I can. But I will take some time. Where where the measurements you mention posted?
Interesting. Where did you see this?
I don't remember if it was here or somewhere else. But someone had posted THD frequency curves for different filters.
Really? THD? Simulations sounds very unlikely. Not sure in what way filters would affect thd.
I wouldn't have expected it to make a difference either, in fact it doesn't make much sense to me. But nevertheless there were graphs, and I can't remember if those were simulations or measurements.
Does anyone know if Paul's latest filters had the DC filter turned on or off? Is there a way to decode the SKR file into text (I guess not)?
Found it, look at posts #891 and following.
These are measurements, not simulations. They are also based on a rather unorthodox methodology where thd is inferred from the impulse response to a single sample.
These are clearly made by Fuzzmeasure on a Mac. It uses a sweep as input.
I'm in the rolling credits in the "About" window ;-) so I have used it...
I wrote "and following". There are also purely calculated distortion figures:
Filter brewing for the Soekris R2R
- Digital Line Level
- Filter brewing for the Soekris R2R
