My first DAC on PCM1794A - help needed.
Old 17th July 2018, 07:58 AM   #31
edwtsui is offline edwtsui  Hong Kong
I am interested to build this DAC too, but have some questions and seeking for help.
1. LME49990 has been discontinued already. I am thinking of replacing the opamp to AD797 or ADA4627, any comments?
2. Why 12 x opamps are needed? Suppose I only need one channel output from one DAC, why not 6 instead of 12?
3. We have one I2S from Raspberry Pi and feed to two DAC PCB, how to do it? Connect in parallel?
Old 18th July 2018, 04:06 PM   #32
Chulia is offline Chulia  Lithuania
Hi, it's definitely worth building it, sound quality is reallys superb!
1) Yes, that's an issue I faced when 3 of them burned :/ Managed to find original replacements. Have no idea about the options you've mentioned, maybe other members could comment on those.
2) In my case by using 12x I'm getting balanced outputs, which is what I need.
3) Yes, since it's a digital signal you just split it and feed however much devices you need.
Old 19th July 2018, 04:27 PM   #33
Thanks for your reply. If I want both balanced and unbalanced output, how should I do for unbalanced part? Simply pick the (+)output and GND and connect to RCA jack?
Old 20th July 2018, 09:04 AM   #34
You should follow the original project then and add the headphones amp IC, which is planned to be there anyways and also has it's tracks on PCBs.
Then you take balanced output right after I/V stage and RCA after HP amp. I'm just not sure if in this case you need to somehow disconnect HP amp when using balanced output.
My first DAC on PCM1794A - help needed.Hide this!Advertise here!
pcm1794a DAC Mute function hug96 Digital Line Level 24 26th May 2015 07:40 AM
PCM1794A tube-output DAC.... 4 chips detroyed wmincy Digital Line Level 23 4th June 2013 12:11 PM
Comments on PCM1794A DAC design novec Digital Source 54 4th June 2012 07:58 PM
Micro DIR9001 + PCM1794A DAC theAnonymous1 Digital Source 88 14th June 2010 09:01 AM
FS: Twistedpear PCM1794A DAC Board pftrvlr Swap Meet 2 18th April 2010 03:52 PM
