Does any one have useful distortion and S/N specs on Najda? - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 7th January 2015, 12:41 AM   #1
Default Does any one have useful distortion and S/N specs on Najda?
I am interested in getting one, but have been denied any real documentation from the company. No graphs of any kind.
Anyone got any distortion and noise specs?
If not, any one willing to do the testing and report it?
Old 15th November 2015, 01:21 PM   #2
Default najda noise and distortion
Did you get an further information on this? Just came across your post after just asking the same question of them via their web site so will await any possible response.
Old 15th November 2015, 05:30 PM   #3
If someone wants to pay roundtrip shipping I'd be willing to measure. However, my audio interface uses the same -100dB THD 114dB SnR Cirrus parts as (I think) the Nadja, so in the best case all I'd be able to do is indicate parity with my measurement floor. If WAF made implementation errors and degraded performance I'd be able to catch that, albeit to limited extent if there is only a couple dB reduction.
For a more capable investigation one can hire Neurochrome Audio's APx525 based measurement service.
Old 16th November 2015, 12:20 AM   #4
...thanks for the offer but on further looking around I came across "Hi-end DSP based multi-channel Preamp/Crossover/DAC project" on DiyAudio which (once available) looks much more promising for my purposes.
Old 2nd September 2016, 10:27 AM   #5
For anyone interested in the Najda parameters, here they are for reference from a test on youtube:
noise: - 120 dB after the analogue DAC section
harmonics: 2nd and 3rd harmonic -102 dB higher harmonics well below -120dB
THD: between 0.001 - 0.004% depending on frequency
jitter: +/- 5 nanosec
The values are from a youtube vidoe from "jipihorn" in French - I hope I understood correctly as my French is a bit rusty. The tester in the youtube video likes the Najda board, especially as the price is competitive. One thing I am a bit concerned about is that while the sample rate can be 96 and 192 kHz for improved DSP calculation precision, the audio bandwidth is limited to 24 kHz by an internal sample rate converter FIR (?) filter, so 96 kHz source material will be filtered to 48 kHz. This probably is not a big problem (Shannon theorem) and may even protect us from intermodulation distortion of supersonic frequencies in the power amplifier. The noise and THD seems to be very good, and while the jitter is not exceptional it is also good enough, as even the listeners heartbeat introduced larger jitter. I really like the flexible gain structure of the board and the analogue volume control! Very tempted to buy a Najda.
The other board mentioned in this thread seems to have fantastic specifications, but the developer already said "not to expect minidsp prices" so I guess it will be quite a bit more expensive and will take a while until it is available; also the software bugs usually take years to be ironed out.
Najda builds - resource list SAC Digital Line Level 19 16th September 2015 07:20 AM
DSP Xover Najda Panels served Digital Line Level 42 17th June 2015 01:36 PM
Najda DSP Crossover fbu Swap Meet 10 26th January 2015 03:22 AM
Najda Board fbu Swap Meet 8 7th December 2014 11:20 PM
Najda Vs miniDSP 2x8 kinku Digital Line Level 0 19th June 2013 02:35 PM
Copyright 1999-2017 diyAudio
