MidSide decoding - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 20th December 2014, 03:21 AM   #1
Default MidSide decoding
Suppose you have L and R signals. MidSide encoding produces signals M=L+R and S=L-R before transmitting.
On the receiver side, decoding is operated as L = (M+S)/2 and R = (M-S)/2. See Joint (audio engineering) - Wikipedia, the free encyclopedia
Question: I have a differential transmission with XLR connectors, so getting M on pin 2 and -M on pin 3 on channel 1; also S on pin 2 and -S on pin 3 on channel 2.
Can I obtain a simple passive decoder by just wiring together the above pins as follows without any further components? Any drawback?
IN:
Channel 1
pin I2: M
pin I3: -M
Channel 2
pin J2: S
pin J3: -S
OUT
Channel 1
pin 2: I2 and J2 wired together (gives 2L)
pin 3: I3 and J3 wired together (gives -2L)
Channel 2:
pin 2: I2 and J3 wired together (gives 2R)
pin 3: I3 and J2 wired together (gives 2R)
-Roberto
Edit: I think I actually obtain L, -L, R, -R in the output pins, as each input pin is used twice, so its signal is halved.
Motivation: the M and S signals are produced in the digital domain and it seems to be better to decode them as L and R in the analog domain after that M and S have been converted through a DAC: https://translate.google.com/transla...-text=&act=url
Old 20th December 2014, 03:20 PM   #2
DF96 is offline DF96  England
If you wire an output directly to another output then the join can only have one voltage. This is still true if you add more outputs to the mix.
I1 and J2 are joined, so they have the same voltage. You then join I2 and J3 so they too have the same voltage - but J2 and J3 have opposite signals. Repeat as necessary. The result is no signal anywhere.
As a minimum you need to add some resistors so the outputs can be mixed without forcing equality. To find suitable resistor values just do a forum search or use Google. Look for 'mono mixing' or 'stereo to mono' or suchlike. Your requirement is slightly different, but the technique is the same.
Old 20th December 2014, 08:38 PM   #3
M-S is relevant only to the original recording side of the chain, where a side-facing bipolar mic is matrixed with a front-facing, matched-response(the tricky part) cardioid/unidirectional mic. Unless you have two tracks where each track is just the direct signal from each such mic, M-S decoding will produce a completely erroneous result. If you do have such tracks, just do a web search on "passive m-s matrix".
Old 20th December 2014, 08:55 PM   #4
@DF96: it makes sense now to me, you are right, no signal anywhere...
@stephensank: I want to experiment, so searching for a passive m-s matrix, I found this info http://www.uneeda-audio.com/ms/ms-mat.htm
Thanks to both
-R
Me again... matrix decoding w/ tubes? sixSixSeven Tubes / Valves 1 23rd March 2011 04:33 PM
Decoding LFE cujo75 Subwoofers 12 28th November 2006 08:06 PM
decoding input guinness Car Audio 1 17th November 2004 12:22 AM
I need help decoding transformer wiring smmcbride Solid State 4 19th December 2002 12:27 AM
Dolby digital 5.1 and decoding... scottylans Digital Source 5 22nd November 2002 04:13 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
