NAD DAC M51 vs. Philips TDA1547 DAC - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 2nd December 2014, 01:36 AM   #1
KrammeAcoustics's Avatar
Default NAD DAC M51 vs. Philips TDA1547 DAC
Hi forum
I've now had my NAD M51 DAC for 1 year and i'm pretty tired of the sound or should i say, i'm missing a more open and detailed sound. The NAD is very closed ...like it's filtered and oversampled to much.
I've ordered a new Philips TDA1547 Assembled DAC from ebay, because i've had a DAC for a couple of years ago ( unfortunately dead ) which contained several TDA1541's and it was very open and detailed.
What's your opinion, could this be a better solution, when it's said that i like open and detailed sound ?
Signal: streaming from pc's in wav format = 44,1 khz via coax or usb.
PS: I've got both 2x16 vac + 2 x 9 vac transformers + enclosure + 2 x opa2132 for this build !
Old 2nd December 2014, 02:11 AM   #2
Info:
If i understand this thread Tda1547 Dac , we are talking about DAC-7 ( when combining TDA1547 + SAA7350 ).
Old 2nd December 2014, 03:56 AM   #3
aparatusonitus's Avatar
IMHO definitely ... but to make DAC7 combo to shine, everything has to be done properly, starting with the selection of the input receiver and digital filter, through several stages of reclocking, proper PSU for digital and analog part, grounding, PCB art, choice of opamps, etc. Only in this case SAA7350/TDA1547 combo is capable of really outstanding sound.
Info:
IIRC, Philips guys use to call TDA1307/TDA1547 combo DAC7 as well.
I almost forgot ... the SAA7350/TDA1547 combo can be converted into a non-oversampling dac also, you just have to bypass digital filter and supply I2S directly to SAA7350 from input receiver.
Non mai abbastanza...
Old 2nd December 2014, 07:54 PM   #4
hi aparatusonitus
thanks for the answers
It seems i've found one of the good DAC's then. what do i have to buy/get for making what you call several stages of reclocking ? is it possible to find schematics or tutorials ?
I'm going to put two seperat trafos to the digital section and a seperat trafo for the analog. i checked the voltageoutput on several trafos yesterday. i got some "okay" ones that gives 17-0-17 vac and 10 vac. but even better, i've got some "quality" ones that has an output of 22-0-22 vac and 12 vac. i looked at the specs of the dac and it only allows +/- 20 % of 16-0-16 vac and 9 vac.
This dac has 317/337 voltageregulators, so i guess it should manage the 22-0-22 vac and the 12 vac input ( or maybe not, without adding better heatsinks ? )
about the op amps, should i go for 5532, 2132/2134 or maybe some 627's ? i only got the 2134pa in stock, so if they are okay i would be happy !
exactly ...i want to have the conversion possibility for non-oversampling. where do i find a schematic, so i know which pins i should use for bypassing ? can i do it with a simple contact or should it be done close to the digital components with a relay ?
Old 2nd December 2014, 08:37 PM   #5
Hi KrammeAcoustics,
How good (or not) your dac is remains to be seen/heard. At this stage I would not recommend to buy anything extra, just what is essential to get it work.
About reclocking...don't lose you sleep over it for now, it's is already implemented in some way or another in you dac pcb, it seems.
As for transformers, use lower voltage one for start, if nothing (LM317/337) is hot, you may use higher voltage ones, regs will become slightly hotter.
For opamps, use what you already have, OPA2132, at later stage you can experiment with another ones.
Without schematic and/or circuit board, it's almost mission impossible for an amateur to do non-os mod, sorry.
Old 2nd December 2014, 09:20 PM   #6
hi again aparatusonitus
again thanks for quick replying. okay i will start simplistic and then we will see if some add-ons and tweaks is necessary :-)
i will definetely get back when i'm ready for the non-oversampling operation !
obs: if anyone else has something related to subject, please feel free to tell.
Old 17th December 2014, 06:18 PM   #7
Hi again
The stuff has arrived and offcourse as a little boy at christmas, i quickly had to crank the new DAC up. In the junkbox i've found a toroidal transformer with 15-0-15 vac + 9 vac and after mounting this and soldered the L+R input signal i was ready to listen. First impression is wauuuw ( some simple guitarmusic from Adam Raferty ). I discovered that there actually is mounted 2 pcs. of 5532 from JRC om the board, even if it was said that there were no op amps included in the price. Okay offcourse i just have to be satisfied with this extras. Anyway i think i'll mount some Burr-Brown OPA 2132 or 2134's of my own in a couple of days.
After a couple of hours listening with one transformer giving all the different voltages needed, i now tried to play with the PS. So now it's supplied from 3 transformers. One toroidal 15-0-15 vac and nr. 2 also a toroidal 1 x 8VAC and nr. 3 is equal as nr. 2. ( i observed that it's only 16 VDC electrolytics after the rectified 9 VAC inputs ). Does it then sound better with 3 transformers ...well i can't say yet. It's obvious that this DAC as any other electronics has to be burned in first. I will try later ...maybe after some weeks to try again comparing 1 vs. 3 transformers and give a review.
An important thing i've noticed is the 7809 reg. is getting very hot ( it has a cooling sink ). but the 7808 does not get hot ....is this normal ? i would had thought these two regulators would get nearly the same temperatur !
Last but not worst, is this DAC worth 75 US $ ? Yes i think so ...i'm glad to have one more DAC to make comparisons with vs. my NAD M51. It has something that the NAD not have and vice versa ( they're night and day up against each other ).
I'm ready for some mods. very soon and if i can get some help from you guys, that would be nice !
Old 17th December 2014, 06:25 PM   #8
Old 17th December 2014, 07:09 PM   #9
temp is 49 degrees C of the 7905 reg and 39 degrees C of the 7805 reg
weird difference i think ...right ?
Old 17th December 2014, 07:18 PM   #10
Temperature of both regs are within specs...the difference in temp is caused by input-output dc voltage difference and loading.
PWM used in NAD M51 vs. DSD? Dan_E10 Digital Line Level 1 19th July 2012 03:38 PM
NAD M51 DDDAC- Eliminating incoming Jitter through conversion process from PCM to PWM tiefbassuebertr Digital Source 1 2nd July 2012 05:53 PM
diyclub.biz DAC-38, DAC-60, DAC-68. Anybody heard? TonyDasilva Digital Line Level 21 13th April 2009 06:10 PM
Tda1547 Dac Cobra2 Digital Source 29 29th November 2008 08:07 PM
TDA1547 dac, different versions? VanHal Digital Source 3 11th July 2007 07:07 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
