Wicked cheap and easy dac - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 27th November 2014, 01:54 PM   #1
branet is offline branet  Croatia
Default Wicked cheap and easy dac
I was wondering if there is a cheap and easy diy dac (USB to RCA) chip. Maybe P2P. I dont need performance I need only for first aid . 16bit preferably.
Old 27th November 2014, 02:02 PM   #2
PCM2906B
PCM2906B | USB CODEC | USB Audio | Description & parametrics
Old 27th November 2014, 08:24 PM   #3
Thanks for an answer .This chip seems to be out of production. Are there a newer chip that it is easier to obtain!?
Old 27th November 2014, 10:26 PM   #4
00940 is offline 00940  Belgium
If you don't need performance, the cheapest and easiest is to grab a small usb soundcard on ebay. The cheapest ones can be found for less than 3€...
The PCM2902C and PCM2707 are still in production and quite easy to implement if you want to build your own. All usb IC I know are SMD so P2P is pretty much out of question.
Ben.
Old 28th November 2014, 07:00 PM   #5
Eldam is offline Eldam  France
Not DIY but certainly cheap : PCM2706 implementation
Cheap and Easy Soft Start? samsagaz Solid State 43 22nd November 2010 09:18 PM
cheap and easy tube preamp juuzo` Tubes / Valves 1 18th May 2009 06:21 AM
Cheap and easy vacuum impregnation pjanda1 Tubes / Valves 24 16th May 2009 08:49 PM
first easy cheap ect... theChris Parts 5 31st January 2003 08:00 AM
Any PCB - easy and cheap Koy Solid State 8 17th July 2001 03:45 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
