Downloading and then burining a CD? - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 23rd November 2014, 08:00 AM   #1
Bare is offline Bare  Canada
Default Downloading and then burining a CD?
Wanting to buy some Joe Bonamassa albums.. I'd like it as CD but don't really want to pay/wait for shipping.
Possible (clever??) to buy the downloads as 320 bps(?) mp3 files then burn my own cd??
Or will this be of lesser quality than simply buying a premade CD??
Old 23rd November 2014, 08:08 AM   #2
Mooly's Avatar
Try it using a CD you have. Just rip it to MP3 @ 320kbs and burn to a CD-R( or RW) as a trial and see how you like it. Remember to burn the CDR as an "audio disc" assuming that is what you want and not as a data disc.
Installing and using LTspice. From beginner to advanced.
Old 23rd November 2014, 10:50 AM   #3
Julf is offline Julf  Europe
Technically it will be of lesser quality, but I doubt you hear a difference.
"To try to judge the real from the false will always be hard. In this fast-growing art of 'high fidelity' the quackery will bear a solid gilt edge that will fool many people" - Paul W Klipsch, 1953
Old 23rd November 2014, 11:31 AM   #4
freax's Avatar
Done this before with FLAC to CD back in 2005-ish and it sounded better than the original files playing from the computer. It worked fine.
"It seems that perfection is reached not when there is nothing left to add, but when there is nothing left to take away" - Antoine de Saint Exupéry
Old 23rd November 2014, 11:41 AM   #5
FLAC is a different story. If you take the FLAC rip of a CD and write it back to a CD, you end up with a copy the original CD. If the FLAC file sounds worse than the CD, then there is something wrong with your computer setup.
A mp3 file can't be unpacked to retrieve the original data - a lot of it has been thrown out. Not that it really matters from an audibility point of view...
Old 23rd November 2014, 12:01 PM   #6
Max Headroom's Avatar
Location: West Australia, straight over the road from the beach, natural ambient sounds only.
I use Cool Edit to batch convert MP3 (320k) files to wav files.
I then use Foobar to burn the wav files to CD.
I use Cool Edit to do the conversion to wav because it utilises the Fraunhofer MP3 codec, which I maintain sounds better than the Lame MP3 codec, plus setting up the batch conversion is dead simple.
The resulting CD's sound perfectly fine, on some programme content actually better than the original wav.
Dan.
Old 23rd November 2014, 12:12 PM   #7
Send a message via Skype™ to JonSnell Electronic
I just download the track from wherever has it for sale, then using Nero burn it as is. Usually MP3. It is also easy to convert the music files to any media type with Freemaker Audio Converter. Video compresses to MP4 well with Freemaker Video Converter. You will be surprised how many MP3's will fit on a DVD, even more on BlueRay!
www.flyingmole.co.uk For World Wide support for Flying Mole, Class D, Refurbishment and Repairs. www.jonsnell.co.uk
Old 23rd November 2014, 01:04 PM   #8
Pretty much all recent controlled ABX tests show that there is very little difference in modern versions of Lame and Fraunhofer, but Fraunhofer encoder is faster.
Indeed, many people prefer mp3 (if they can tell a difference), probably because the codec throws away "irrelevant" data, and gives more focus to the more important (to the ear) components in the music.
Old 23rd November 2014, 01:30 PM   #9
I did some testing until way late at night/morning (clean power/no background sonic noise) and came to the conclusion that PB of Fraunhoffer 320k MP3 encoded tracks on multiple MP3 player devices sounded better than the same tracks encoded using the Lame 320k MP3 codec.
To be fair, the differences between the two codecs is subtle, but I consistently found the Lame codec to add a 'nervousness' vibe to the music, while the Fraunhoffer sounded nicely more musical.
Yes, my intro to this was I had a Kylie CD floating around on my repairs bench as a test CD.
In came a MiniDisc machine (ATRAC audio data compression) with a pre-recorded minidisc version of the same Kylie album.
I was able to cue both sources and switch between them in real time.
I came to the conclusion that I preferred the minidisc version because it threw away/reduced dross in the recordings.
This dross also stimulates production of more dross (exponential rise) in typical less than perfect PB systems...a win/win situation in a sense.
Dan.
Old 23rd November 2014, 04:46 PM   #10
Thank you gentlemen.
Still not sure as to what all the above means .. in real life.
All those codecs / converters are as Greek at this point of my learning curve.
Clearly I will have to experiment.
Am (was?) concerned that after 40 years of building towards a playback chain that is genuinely 'good'.
I would be inadvertently negating a lot of it's resolving power ?
Whether that extraneous recording detail, erm.. dropped, is dross or not, only experimentation will tell.
The Elephant in the room question being: is it about the Music OR the sounds.
I prefer both when possible.
Downloading a plug in again. strider75 miniDSP 3 10th April 2013 09:26 PM
Help downloading speaker test tones head_unit Multi-Way 2 14th October 2010 06:51 AM
Pages don't complete downloading Michael Koster Forum Problems 4 2nd May 2010 04:34 PM
Downloading schematics Ejam Forum Problems 0 16th September 2009 12:45 AM
Help downloading music woody Everything Else 4 30th June 2008 01:22 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
