freeDSP - an open source 2-in 4-out digital crossover board
Old 19th June 2017, 02:11 PM   #311
zdr is offline zdr  Belgium
zdr's Avatar
Originally Posted by Mayday View Post
Nice
Any renderings of the board?
Here you go
Neb.
Old 19th June 2017, 03:00 PM   #312
Mayday is offline Mayday  Sweden
Mayday's Avatar
Originally Posted by zdr View Post
Here you go
Mmmm, diy-p0rn haha
The more you learn, the more you realize how little you know...
Revived my blogg
Old 17th July 2017, 04:35 PM   #313
princenk007 is offline princenk007  India
princenk007's Avatar
This thread is getting interesting by the page.
Excellent work by zdr. very pro looking. This is like freedsp going to the next level.
It has been almost a month now since the last update. Any progress lately zdr?
Old 17th July 2017, 06:05 PM   #314
zdr's Avatar
That's pretty much it for now, I have got everything I need in there. I am waiting for new prototypes to arrive while I am on vacation till September. Latest boards will have additional two dacs at the output instead of two adc circuits which don't make sense with AW on board anyway.
Sent from my MI 6 using Tapatalk
Neb.
Old 30th July 2017, 09:38 PM   #315
Piersma is offline Piersma  Netherlands
Piersma's Avatar
Default AMBIOPHONICS PLUGIN
hi all,
Does anybody know if there is a AMBIOPHONICS plug-in for Sigma Studio available?
Old 20th September 2017, 10:13 PM   #316
Viper_user is offline Viper_user  Europe
Viper_user's Avatar
Is there any way to setup a 4way crossover with those boards?
  • s-pdif digital in (2ch)
  • (8ch) rca analog out
Thanks for advice!
Old 20th September 2017, 11:47 PM   #317
Andrew Eckhardt is offline Andrew Eckhardt  United States
I posted the same question last December. Since then I've done it. At a minimum you need to supply a master clock as the ADAU1701 sheet warns against attempting to distribute it from the internal oscillator. Tie the audio bus from receiver to both boards. There was some cutting and pasting on the FreeDSP and receiver boards involved for me, but I went to a 24.576MHz clock and 96kHz sample rate. When I went to 96k there was also something odd about master/slave configuration in hardware and software, but I don't recall exactly what that was. My documentation skills stink, and I was only out to get the setup running once for myself. In short, it can be done, but it would be really nice if someone would do a different board specifically for this. Also, if you're looking for killer sound you'll probably want a better DAC. The internal ones are OK, but not great. The CMOS filter opamp on the board is not great either. Similar technology is probably used in the 1701 internal voltage output , but I think the sound is better with passive filtering. I did a 3-way with a pair of the 1701 DAC outputs paralleled on the hi pass, and a fancier 2 pole filter there. I'll eventually use a "real" DAC and active filters, still based around the 1701, unless a better/cheaper DSP chip comes along first..
Old 21st September 2017, 09:59 PM   #318
Viper_user's Avatar
Ok to bad there is no board yet. Maybe this will do?
miniDSP Kits : nanoDIGI 2x8 K
If you add 4 Dac's.. on what board? China?
Do you recommend 1701 DAC?
1PCS PCM1701P DAC IC
The chip has no board and p supply kit.
Cheers!
Old 9th October 2017, 12:15 PM   #319
zdr's Avatar
Cheers!
I believe my board should be able to do up to 12 channels, but I'll have to doublecheck. 6 DACs are onboard, and the rest is available through expansion I2S pins.
Neb.
Old 10th October 2017, 09:02 AM   #320
zdr's Avatar
My board is done, works great! I need to finish my sub now so that I can do some proper listening to a full blown stereo 3-way crossover. I also have rotary encoder volume control working on GPIO expansion ports. Programming works through USBi and Arduino Nano.
Next step is to do volume control, IR remote and LCD volume display with Arduino on already board.
Neb.
freeDSP - an open source 2-in 4-out digital crossover boardHide this!Advertise here!
ClassD Open Source Development Board TroelsM Class D 19 11th February 2014 07:20 AM
Ultimate Open Source XMOS USB-I2S: The source to end all sources. krfkeith Digital Source 4 14th June 2013 04:54 PM
Volume / Source selector - open source project ? AuroraB Analog Line Level 22 22nd September 2012 03:21 PM
Need Testers/Developers for open-source Excel based Crossover Design Tools CharlieLaub Multi-Way 40 6th May 2012 11:31 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 08:33 AM
Copyright ©1999-2017 diyAudio
