First post, so I'm sorry if it's in the wrong forum...
anyway, would an AKM AK439X DAC be able to connect to an Intel edison via I2S?
Basically yes but at least Arduino pins have no MCLK output available:
EmutexLabs
Don't know if you can configure I2S to work as slave on Edison, if yes then you also need a device generating the audio clocks for bot the codec/DAC and Edison.
EmutexLabs
