MiniDsp 2x4 low gain problem - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 29th August 2014, 04:50 PM   #1
Default MiniDsp 2x4 low gain problem
Has anyone investigated solutions to low output from this unit. I have not seen a schematic anywhere on this. I'm assuming that it has an opamp based analog out, somewhere in design ,that the gain could be adjusted with resistor changes.
Old 2nd September 2014, 10:36 AM   #2
It doesn't have output opamps unfortunately.
Old 2nd September 2014, 10:42 PM   #3
Yes I've done some research hence and found that out. Do you know i hear that the balanced design will solve this. I'm assuming though that requires a balanced input on the amp driven? You can't drive an unbalanced with balanced correct. one phase will be connected to signal ground. This is a major drawback to this DSP design. Low output makes it impractical.
Old 3rd September 2014, 01:30 PM   #4
Julf is offline Julf  Europe
Absolutely no problem driving balanced with unbalanced - it is the other way that is trickier.
A balanced input is differential - it looks at the voltage difference between the non-inverting and inverting input. It doesn't care if one of those happens to be connected to earth/ground.
"To try to judge the real from the false will always be hard. In this fast-growing art of 'high fidelity' the quackery will bear a solid gilt edge that will fool many people" - Paul W Klipsch, 1953
Old 3rd September 2014, 09:09 PM   #5
CharlieLaub designed gain stage boards for the minidsp. See posts #74 and #76 here:
4-channel gain stage with DC-servo for MiniDSP
Old 4th September 2014, 03:44 PM   #6
More recently I have designed a board (being fabbed right now) that employs a 4-channel VCA for post-crossover volume control, including up to 12dB of boost, the output level of which is controlled by a single 0-5V DC signal. This lets you run the miniDSP board at "full signal" levels, and then do the volume control in the analog domain. Because it can provide gain as well as attenuation, this approach solves multiple problems at once. Once I get it built up I will do some tests for performance (e.g. distortion and noise, etc.). There are other solutions that are coming down the pipeline (not from me however) that can do the same thing using more contemporary technology (digitally controlled volume ICs).
"Hardware eventually fails. Software eventually works" - Michael Hartung
WTB MiniDSP 2x4 schmalex Swap Meet 2 30th May 2014 05:20 PM
WTB: MiniDSP 2x4 Westy37 Swap Meet 1 9th July 2013 10:22 AM
My new miniDSP 2x4 mluc8 Digital Line Level 4 11th December 2012 02:54 PM
2 2x4 or 1 2x8 MiniDSP Frosteh Digital Line Level 6 23rd August 2011 12:25 PM
miniDSP 2x4, a new home for miniDSP minidsp miniDSP 8 27th August 2010 01:11 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
