Minidsp 2x4 not recognized/can't connect - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 27th August 2014, 06:00 PM   #1
Default Minidsp 2x4 not recognized/can't connect
I have solved my problem with the 2x4 minidsp.
I could not connect/synkronice on 2 of my board,s.
Many times it succeded fidling with the minidsp usb connection on the board.
I have ordered new female miniusb connectors,but discovered that it is the coil L3 that is causing the problem.
I removed it ,a 4 leads SMD thing ,placed very close to the miniusb connector.
Bypassed it ,and it Works fine.
[IMG]Click the image to open in full size.[/IMG]
This board is an older version ,but the problem was the same on a newer one with 5 pins to external USB connector.
Pleace report if you coudd use this .
Bernt "Båndsei"
Old 28th August 2014, 08:19 PM   #2
TNT is offline TNT  Sweden
TNT's Avatar
I have the same problem - must try this...
Old 3rd September 2014, 03:54 PM   #3
Hi TNT
Have you tried to bypass the "coils"?
Bernt
Old 20th September 2014, 08:46 AM   #4
TNT's Avatar
Not yet but I'm about to now...
Old 20th September 2014, 09:46 AM   #5
TNT's Avatar
I tried to bypass but no improvement, Actually, my computer see the device on USB level but connecting straight to a USB input gives the trying 1, 2, 3 fail. Using a USB 2 hub gives timeout directly with a disappearing "Resync" button. But it seems the USB configuration goes better with the hub as now the Vendore etc is discovered. In both cases the USB device was seen by the comp. Adobe Air of latest fashion.
I will now remove L3...
Old Yesterday, 03:13 PM   #6
Hi TNT
I have tried to bypass without remowing the "coils"
I used 1.8 ohm resistors,same value I measured on the coil,but it did,t Work .
I had to renowe the "coils" and mmake a short shown on the Pictures.
Please ´tell us if you susceded.
Bernt
Old Yesterday, 03:15 PM   #7
TNT's Avatar
Didn't remove L3 .. yet...
This feels like a SW fault on the client side....
Old Yesterday, 03:43 PM   #8
Davey is offline Davey  United States
Yeah, I think so. If the series coil was open/failed the board would not power up at all.
Dave.
Old Yesterday, 03:45 PM   #9
TNT's Avatar
I don't think this board is USB powered....
There is a 12 v feed also... for sure it works without a connected USB cable.
Old Yesterday, 03:47 PM   #10
TNT's Avatar
Originally Posted by båndsei View Post
Hi TNT
Bernt
OK, thanks, I need to do it... I'll get back.
WTB: MiniDSP 2x4 Westy37 Swap Meet 1 9th July 2013 10:22 AM
My new miniDSP 2x4 mluc8 Digital Line Level 4 11th December 2012 02:54 PM
miniDGI with miniDSP 2x4 Pascal GUERIN miniDSP 2 8th January 2012 12:45 PM
2 2x4 or 1 2x8 MiniDSP Frosteh Digital Line Level 6 23rd August 2011 12:25 PM
miniDSP 2x4, a new home for miniDSP minidsp miniDSP 8 27th August 2010 01:11 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
