Modify behringer DEQ2496?
Old 10th July 2013, 11:47 PM   #221
Pano is offline Pano  United States
Pano's Avatar
All great improvements, as far as I can tell.
Old 11th July 2013, 12:03 AM   #222
petefrontiers is offline petefrontiers  Canada
Thanks Pano. I still have to find where to connect the BNC digital input on the board and change on board regulators and I think it will be the best that I can do with it I had a Sonic Frontiers SFD1 mk II on hand last winter to compare and I prefered the modified DEQ.
Old 11th July 2013, 12:29 AM   #223
Kirchhoff is offline Kirchhoff  Canada
Please kindly post those measurements, we're all curious.
Until then here's an existing measurement performed on a stock unit:
Does Your Studio Need A Digital Master Clock?
I actually was very pleased with the stock unit, I use it as Digital In -> Analog Out, it had a certain easiness in the treble that my more expensive CD players didn't, they were "grainy" and "dark" in comparison.
I went for some more modest mods, my purpose was to improve reliability/lifetime, so I did nothing but replace the electrolytic caps with long life 105C and 125C rated versions. Except the interstage audio signal ones where I found that in positions with 0V DC bias, bipolars worked best, so I settled for some 85C Panasonic SU there. I also added heatsinks to the processors. That was all I did and I am very pleased with the end result, I don't feel the need to go any further.
Old 11th July 2013, 01:06 AM   #224
Pano's Avatar
I posted mine a few years back in one of the DCX threads. Would need to dig to find them. The differences were easy to see. I have not done clock mods yet.
(thanks for the link!)
Take the Speaker Voltage Test!
Old 11th July 2013, 04:04 AM   #225
noSmoking is offline noSmoking  United States
noSmoking's Avatar
Default hi FLAVIO MARINS
[QUOTE=FLAVIO MARINS;3554961]An enthusiastic YES!
Hi Flavio,
I have a deq and 2 dcx2496's I am getting ready to mod all of them ,they will work together in my system trying to stay digital as far along as possible,I for one would be interested in your tests and recommendations of what to upgrade and the results from these mods,I have read on this site that alot of folks are replacing the PS,DAC,regs and other output mods what is your mod list?
What mods do you think improved the sound the best?
Thanks alot,
NS
Old 15th July 2013, 05:14 PM   #226
Jaimo is offline Jaimo  Canada
Default Past posts
Here's two past posts for the Deq2496. Keep in mind that there are many similarities between the Dcx and Deq output stages. Switching to an Ak4396 dac is another option to consider.
http://www.diyaudio.com/forums/digit...-bother-4.html
http://www.diyaudio.com/forums/digit...ml#post2087716
Old 20th January 2014, 08:41 AM   #227
alemonifra is offline alemonifra
Hello, I'm new, I introduce myself:
my name is Francesco and I live in Italy, I apologize for my English but I hope you can understand it.
I have a DEQ2496, i would like to modd it using the direct out, Behringer 2496 direct out mods, but I'm not very experienced, it is very difficult for me to understand by means of writing, you can put a design of the schema?
Francesco
Old 1st July 2014, 03:38 PM   #228
Strosek is offline Strosek  Canada
Just wondering if I could get some guidance as to optimum placement of some high end caps on the main board with the DAC. I'm going transformer direct out so giving the dac chip as much love as possible is job one. I also have the older version board.
Here are the options:
Black Gate NX series HI-Q 22u 6.3v ** Only have 2 **
Oscon 47uf and 180uf
and
Elna Simlic II and Panasonic FC all values on hand...
My primary goal is placing the right cap on the correct location based on qualities of each cap.
PETEFRONTIERS I'm using R7 top side closest to the connector as spdif input.
Old 2nd July 2014, 02:11 AM   #229
and
Thanks for telling the location for the spdif input. I will try it.
For the caps on the main board, You should change C2, C3, C10, C11 and C20. These caps are filtering the voltage feeding critical chips. I went with 15 uF - 25V Oscon caps but you can put what fits in if they are better than original 10 uF caps
Old 5th August 2015, 09:42 PM   #230
hopeful7 is offline hopeful7
Red face DEQ 2496 for hearing impaired (deaf) musician***
I purchased one of these deq 2496 so I could use compression and eq to mimic the functions of my speech engineered hearing aids. This is definately a basic hearing aid processor in a box, Because with the limiter and compressor and dynamic eq, I can listen to my own musical compositions again without blowing out my ears.
I do wish to do the low distortion aux output mod (will be using aux out into a generic headphone amp) and heat sink the right chips and maybe do some Cap upgrades.
Theres a guy in England who has an aux output mod kit and im trying to reach him but havent been successful and wonder if there are less invasive ways of adding protection to the caps or improving the output. I do know how to attach a mini cooling fan near the supply and heatsink a chip.
Modify behringer DEQ2496?Hide this!Advertise here!
Behringer DEQ2496 Schematic Claus Digital Line Level 12 10th July 2011 02:40 AM
FS:Behringer DEQ2496 Ryssen Swap Meet 15 16th April 2009 09:24 PM
Behringer DEQ2496//Non-Delay Mod**HELP** syntaxsinner Digital Line Level 5 26th April 2006 04:27 PM
FS: Behringer DEQ2496 UltraCurve Pro Rescue Toaster Swap Meet 3 4th February 2006 02:38 AM
Behringer DEQ2496 into T Amp? joesan Digital Source 7 19th October 2005 11:30 AM
