| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#11 |
Hi KYW,
what would be a good output trans? I have got a UTC W-786 600 to 600 trans on hand, thinking about using as a balance cable to single conversion . |
#12 | |
You need +/- 15V op-amp. |
#13 | ||
Previously: Kuei Yang Wang
Konnichiwa,
Sayonara |
#14 | ||
Konnichiwa,
Sayonara |
#15 | |
Mine is +/- 15V. It use JRC LM7815A et LM7915A in the switched power supply (It has 17,7V before the regulators). It has +15V on the red wire, -15V on the second wire of the power connector. I used OPA2604AU. |
#16 |
Thanks KYW.
Strange, it seems there are different configure out there for this gear. Mine uses LM317 & 7805. I found only those 2 regulators on board, maybe there are smaller ones that I've missed. Here's the pic. |
#17 |
These are for the digital board power only.
In fact, the +/- 15V regulators are in the switched power supply. Have a look. It's wrote on the PCB (IC1: 7815 and IC2: 7915). Power connector: 1 Red = +15V 2 = -15V 3 = 9V 4 = 15V ground 5 = another ground 6 = 5V 7 = 3V But the best if you want to be sure is to test on the op-amp pins... |
#18 |
Your are right, I see the 7915/7815.
And thanks for the power connector info, very useful. One thing is bugging me after a bit of probing on the output circuit. Why are there ceramic caps directly couple to the balance out, it is directly in the signal path!!! Surely this can't be good!! |
#19 |
Post a picture.
#20 |
If they are connected to ground, it is to remove switching noise.
| Behringer DEQ2496 Schematic | Claus | Digital Line Level | 12 | 10th July 2011 02:40 AM |
| FS:Behringer DEQ2496 | Ryssen | Swap Meet | 15 | 16th April 2009 09:24 PM |
| Behringer DEQ2496//Non-Delay Mod**HELP** | syntaxsinner | Digital Line Level | 5 | 26th April 2006 04:27 PM |
| FS: Behringer DEQ2496 UltraCurve Pro | Rescue Toaster | Swap Meet | 3 | 4th February 2006 02:38 AM |
| Behringer DEQ2496 into T Amp? | joesan | Digital Source | 7 | 19th October 2005 11:30 AM |
| Page generated in 0.10741 seconds (75.26% PHP - 24.74% MySQL) with 11 queries |
