Go Back   Home > Forums > Source & Line > Digital Line Level
Old 29th January 2008, 06:05 PM   #121
Originally posted by Ryssen
Would this work with a LT1763 2,5v?Different pinout ofcourse.
I don't know. The DEQ v2 was not mine. Just one to upgrade and it left.
In fact, I don't realy know what is this component. I took a picture.
It can be read: F D65AB and 11120 05/06.
Seems to be from Fairchild.
Concerning the 3.3v, I also discovered that inside the DEQ v1, Behringer mixed analog and digital 3.3v. They produce analog 3.3v with the same 3.3v and just insert a coil just before the chip pin... As in the DCX in fact.
Have a nice digital low noise psu is important in fact.
Vote for the DEQ2496
http://www.awdiy.com/
Old 29th January 2008, 06:30 PM   #122
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Ok,but in DEQv1 (the one I have)maybe the LM317 could be substituted with a LT1763 2,5v on one of your miniregPCB`s?
Regards Åke
Old 29th January 2008, 07:56 PM   #123
We need to look what is powered first with 2.5v. In theory, you can remove the 2 resistors and fit a fixed reg in place. But good luke with the legs.
Let me finish do draw the dsp board psu. I'll post it tomorow.
Stef...
Old 30th January 2008, 07:35 AM   #124
DEQ2496 v1 DSP PSU schematics
http://www.awdiy.com/index.php?page=references
Look what they have done with ground and to produce the analog 3.3v...
Old 30th January 2008, 11:57 AM   #125
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Stephane,
Good job! Isn't this the same supply that is used in the DCX2496?
Jan Didden
Old 30th January 2008, 01:22 PM   #126
Originally posted by janneman
Stephane,
Jan Didden
No exactly the same. If I understand the DCX schematics, they produce the +3.3vA with the +5vD using a transistor. On the DEQv1, they directly use the 3.3vD with a coil to ovoid high frequency go back.
The big difference between the DCXv1 and the DEQv1 is ground plane. Only one mixed for the DEQ (AGND and DGND pins from AKM chips directly connected to the same ground). One analog and one digital for the DCX. DEQv2 DSP seems completely redesigned on this.
This may be explain why with the best possible psu, we still have a low level ground noise.
Old 30th January 2008, 02:00 PM   #127
zanash is offline zanash  United Kingdom
stef1777
nice web site !
Old 30th January 2008, 03:55 PM   #128
AR2 is offline AR2  United States
Master Burner
AR2's Avatar
Stef, with that knowledge wouldn't be the best to redesign your board and include all those voltages, including 9V regulated, or make separate board that will solve these issues. After that we just have to look where to cut the traces and completely abandon Behringer PS mess. It seems like that there is no other option. That way we could have one universal power supply for DCX and DEQ, that could incorporate your nice regulators. I have schematics for DCX that shows DSP power supply regulators (not switching supply) and will be happy to send them to you if you need.
www.burningamp.com
October 1, 2011
Old 31st January 2008, 07:09 AM   #129
did you consider discrete psu for each voltage a la audio synthesis ?
Old 24th March 2008, 06:29 AM   #130
badduh is offline badduh  Netherlands
Default Re: Deq2496 direct out mod
Originally posted by sendler
I like the direct out mod.
http://mysite.verizon.net/vze4c5pt/id14.html
That looks very interesting, i was looking for information to upgrade the opamps and caps, but i like to try this mod first. unfortunately I'm a newbie to dacs so i can use a little help
I can't see on the photo how the caps are wired up, could someone please explain that to me?
Behringer DEQ2496 Schematic Claus Digital Line Level 12 10th July 2011 02:40 AM
FS:Behringer DEQ2496 Ryssen Swap Meet 15 16th April 2009 09:24 PM
Behringer DEQ2496//Non-Delay Mod**HELP** syntaxsinner Digital Line Level 5 26th April 2006 04:27 PM
FS: Behringer DEQ2496 UltraCurve Pro Rescue Toaster Swap Meet 3 4th February 2006 02:38 AM
Behringer DEQ2496 into T Amp? joesan Digital Source 7 19th October 2005 11:30 AM
Page generated in 0.12616 seconds (80.14% PHP - 19.86% MySQL) with 11 queries
