| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#111 |
Fixed it with tape on the bottom of the chassis, same as in one of my DCX's. Tape can work wonders in shorty Behringer gear.
#112 |
#113 |
I got a new DEQ2496 v2.4. it seems that the DSP board have been heavily modified. A first look show that crystals have been moved to another locations, LM317 to produce the digital 2.5v removed (and replaced by a dedicated regulator), new uController, some capacitors better placed close to the chips, etc...
No yet checked analog board. . |
#114 |
I'd like to "modify" my DEQ so that it boots and works when I turn it on instead of seeing the flashing display and hearing relays doing an endless clicking cricket imitation. *sigh*
#115 | |
#116 | |
#117 |
Scott |
#118 | |
Below is a summarize of the changes found in the new DEQ v2. On the DSP board: - new specialized uController: an Analog Device ADSP-BF531 remplace the Triscend TAS04 - new SDRAM memory chips - LM317 removed and replaced by a dedicated circuit close to the BF531. Seems to be SOT223 reg but not checked yet in detail. Ref printed on reg google nothing. - crystals moved to a new location, better placement (shorter traces) - complete new traces and ground plane (a lot better than old version) - large smd coils on the 9v input On the input/output analog board: nothing except RoHS. I hate new solders. Need to be clean-up a lot to solder something else. On the switched mode psu: shielded box around the transformer No more thermal adhesive on the connectors (good !!!) AC input connector inverted. More stickers and signs on the TOP (a real marketing tool for Behringer !!!). Sound same apparently. |
#119 |
On my web pages, you will find new details on the capacitor modification. I added 2 tables with the use and replacement parts for each of the capacitors on the Analog Input/output and DSP boards.
http://www.awdiy.com/index.php?page=...-deq-caps-mods . |
#120 | |
Regards Åke |
| Behringer DEQ2496 Schematic | Claus | Digital Line Level | 12 | 10th July 2011 02:40 AM |
| FS:Behringer DEQ2496 | Ryssen | Swap Meet | 15 | 16th April 2009 09:24 PM |
| Behringer DEQ2496//Non-Delay Mod**HELP** | syntaxsinner | Digital Line Level | 5 | 26th April 2006 04:27 PM |
| FS: Behringer DEQ2496 UltraCurve Pro | Rescue Toaster | Swap Meet | 3 | 4th February 2006 02:38 AM |
| Behringer DEQ2496 into T Amp? | joesan | Digital Source | 7 | 19th October 2005 11:30 AM |
| Page generated in 0.12843 seconds (76.26% PHP - 23.74% MySQL) with 11 queries |
