| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#101 | |
Where in the data sheet does it say that? Can you show that part? I didn't find it. AFAICS, the outputs sit on 2.5VDC. You can't make that disappear.... Unless you do a balanced to SE conversion as noted before. Jan Didden
/New Linear Audio publication: Baxandall & Self on Audio Power! |
#102 |
#103 | |
#104 |
stupid question, how do I open eso.rar ?
#105 | |
GRG |
#106 | |
use winrar - google to find
No longer powered by Linux - not enough apps and cross platform integration - but maybe one day |
#107 | ||
Anyone done this?
Regards Åke |
#108 | |
Regards Åke |
#109 |
Yes, I know this is an old thread...
Anyway, inspired by this & this , I recall the wonderful DIY DAC I used several years ago, which came with transformer line stage. That DAC was an evaluation board of CS4397 & I skipped the whole analog stage on the board with a pair of Lundahl 7902. That was inspired by this. Tranformer-coupled DAC is awsome, period. By comparison, the OP analog stages sound mechanical & grainy. On the other hand, transformer-couple sound lifelike & fluid. In good recordings, the sparkle & airy decay of the cymbals are simply amazing. In those records without noticeable trebles, the "atmosphere" are also remarkable.... Sadly the evaluation board died after only about 1year of use, and I could not fix it. (tried but failed) Later I bought DEQ2496. Using it with digital input & analog output, it serves both EQ & DAC functions. In the EQ portion, it's doing great. In the DAC portion, it's not. Looking into the boards inside the DEQ2496, those tiny SMD scared me away everytime. (you guys who can deal with them just amaze me! ) So, despite the imperfection of the analog stages, eventually I get used to its sound. Until now. I think, I made a tranformer-coupled analog stage before, why not now? I traced the analog output pins of AK4393, I found they connet to R13, 14, 16, 17 (2k in value) on the back of output board. R13/R14 are L-/L+; R16/R17 are R+/R-. I just attach thin wires on them & connet to pin2/3 of the output connectors. (Of course those connector are disconnected from the board) I need the AUX output for other usage so I leave everything else untouched. Now the DA chip is driving both downstream coupling transformer & the analog stage of AUX output. Maybe or maybe not, I'm not sure. With extra load of 10k, I'm not worried. Anyway, all those tiny SMD and copper foil traces are so complex to me and I'm not willing to destroy any of them. So I'd better leave it that way... Now the output of the XLR connetors is differential with 2.5V DC offset. Luckily those wonderful Lundahl 7902 are now sitting at the input of my preamp with floating primary winding. So the DC offset dose not matter. The fluid, airy, open sound came back immediately. Oh, how I miss that. So, with only 4 short & thin wire, the sound of this box transforms a great deal. The drawback is, the output level drops a lot. I must turn up a lot more on the knob. And the punch, dynamic, energy of the bass seem weaken a bit. This dosen't bother me very much, since the textures & overtones are now much much better which overshine. |
#110 | |
| Behringer DEQ2496 Schematic | Claus | Digital Line Level | 12 | 10th July 2011 02:40 AM |
| FS:Behringer DEQ2496 | Ryssen | Swap Meet | 15 | 16th April 2009 09:24 PM |
| Behringer DEQ2496//Non-Delay Mod**HELP** | syntaxsinner | Digital Line Level | 5 | 26th April 2006 04:27 PM |
| FS: Behringer DEQ2496 UltraCurve Pro | Rescue Toaster | Swap Meet | 3 | 4th February 2006 02:38 AM |
| Behringer DEQ2496 into T Amp? | joesan | Digital Source | 7 | 19th October 2005 11:30 AM |
| Page generated in 0.12598 seconds (84.86% PHP - 15.14% MySQL) with 11 queries |
