Lite DAC-AH distortion repair - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 3rd August 2014, 10:53 AM   #1
svs88 is offline svs88  Finland
Default Lite DAC-AH distortion repair
Hi there,
I got faulty Lite DAC-AH on my hands and now i am trying to repair it.
The problem is that it gives a lot of distortion (like bad signal on radios). Issue is with coaxial and also with optical input so the problem is not there. Also the distortion is same on both channels so i quess its not issue with op-amp circuit.
Measured all regulator output and they seem to be ok. Fixed the common issue with wrong resistors and adjusted TDA1543 dac chip outputs to correct 3.3V. Did not solve the problem.
Heres the circuit:
http://www.audiodesignguide.com/DAC/...ircuit_new.JPG
What to do next? If one of the eight TDA1543 chips are bad, could that add distortion to the signal?
Thanks in advance.
-Samu
Old 3rd August 2014, 11:02 AM   #2
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Lots of distortion affecting both channels sounds more likely to come from the digital receiver not locking properly. Do you have an oscilloscope? If so it would be worth checking the frequency of the word clock when locked to the input.
No matter if we meanwhile surrender every value for which we stand, we must strive to cajole the majority into imagining itself on our side - Everett Dean Martin
Old 3rd August 2014, 11:28 AM   #3
Hi abraxalito! Thanks for fast answer.
Yes i have oscilloscope. How i can check that?
Old 3rd August 2014, 11:33 AM   #4
abraxalito's Avatar
Pin 2 of the TDA1543s is the word select - look for 44.1kHz on here with stable edges. If the edges of the squarewave move around there's a problem with the receiver IC. (I'm assuming you're feeding the DAC from a CD player).
Old 3rd August 2014, 11:39 AM   #5
Currently running it with PC. Ill check that later today, thanks again!
Old 3rd August 2014, 02:07 PM   #6
See the attachement, looks ok to me..? not accurate scope enough?
Old 3rd August 2014, 03:05 PM   #7
Kastor L's Avatar
Send a message via ICQ to Kastor L
Was it sounding normal and one day suddenly became distorted?
I read about someone trying to install OPA627 once in a Lite DAC and it resulted in "lots of distortion" iirc.
SKY reference
Old 3rd August 2014, 03:07 PM   #8
Bought one broken while ago and now started to fix it. This seems to have ad847jn opas.
Old 3rd August 2014, 03:31 PM   #9
Kastor L's Avatar
Mine had AD847 as well.
Does the distortion turn on and off when you flick the optical / coax switch?
It could be the optical / coax chip or a toasted DAC chip, try measuring all eight maybe?
SKY reference
Old 3rd August 2014, 03:54 PM   #10
Without cable i can hear very high tone, definately not should be there but distortion ends.
DAC chips are in parellar so i quess it is impossible to diagnose those without removing them one by one?
EDIT: Also when i start to play music the distortion sound increases a lot.
EDIT2: Interesting.. DAC chip that is second from top (near to trimpot, see image below) is quite hotter than others.. is this normal?
http://www.diygene.com/store/image/c...-1600x1200.jpg
FS: Lite DAC-AH usp1 Swap Meet 0 27th July 2011 05:24 PM
$175 LiTe DAC-Ah NON-O/S anyone? MrDodo Digital Source 17 7th December 2008 07:29 AM
Lite DAC-AH resistor Values recca Digital Source 4 29th November 2007 06:33 AM
LiTe Dac Ah Puffin Digital Source 10 5th August 2007 07:19 AM
LiTe Dac ah Puffin Digital Source 3 31st May 2006 08:08 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
