Blue screen problem with Hifimediy Sabre U2 DAC - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 29th April 2014, 11:50 PM   #1
Default Blue screen problem with Hifimediy Sabre U2 DAC
Hi friends
I ordered the U2 dac 10 days ago and I have received the U2 DAC yesterday. You can see the DAC below.
HiFimeDIY Sabre U2 Asynchronous USB DAC
I really like the sound of the DAC's analog performance. The sound is really good for the price. Overall sound is better than my Asus Xonar DX sound card. But I have a problem with the DAC. I have 2 pc. And the DAC doesnt work now with one of the pc. You can see the details below.
I really appreciate if someone can help me. Or is there anyone which has similar problem with this DAC.
Yesterday I tried it on my htpc (1st pc) with USB 3.0 port and there was no problem.
After that I decided to move the DAC to my other pc (2nd) which has a Asus Xonar DX sound card, to compare the performance of each item. The DAC was connected to the USB 3.0 port and there was no problem again.
But today when I started my 2nd pc, I have seen that windows was not recognizing the DAC. So I tried to plug the DAC on the other USB ports. Dac didn't work with any of them, additionally when I re-plug the on the USB 3.0 port, my pc got a blue screen. To be sure I restarted the pc for few times more, when I plug the DAC on usb 3.0 port, pc got a blue screen. I couldnt understand why it doesnt work on next day. I shut down the pc when the DAC was working flawlessly and started on next day without any change.
After that I decided to give a second chance to the DAC with the htpc (1st pc). I thought that there can be a handshake issue with USB 3.0 ports and firstly I pluged the DAC to usb 2.0 ports. I have 6 different usb 2.0 ports on the mb. But the DAC doesnt work with none of them.
So as a last chance I pluged the DAC on the front USB 3.0 ports. Suddenly the DAC has started to work. I couldnt understand why it behaves like that. And to be sure I unplugged the DAC and tried with the other usb 2.0 ports, again it didnt work. But when I replug to the USB 3.0 port, it started to work. Now it is working with his dedicated USB 3.0 port.
I couldnt understand why the DAC reacted so differently with these pcs. Both pc has windows 7 Ultimate (64bit). And both USB 3.0 chip is from NEC on both pc. And I installed the same driver on both pc's which is provided on your webpage.
I wanted to learn if someone had a problem like that and if you solve this problem.
Thanks in advance
Old 5th September 2014, 03:38 PM   #2
trubul is offline trubul  Poland
Please tell me you've found the solution? I have a similar problem with USBs - this DAC doesn't work on USBs 2.0 and on USB 3.0 it sounds laggy, I have some drop-outs.
Any help?
Greets.
Hifimediy Sabre dac on Windows 7 or 8 64bit install TugaTweaker Digital Line Level 8 24th January 2013 11:53 AM
AKAI AM-u2 amplifier problem no output on speaker. yash1 Solid State 0 30th December 2012 02:07 PM
115 V wiring for Hifimediy Sabre Coax/Optical DAC ES9023 +CS8416 192k/24 AngleCard48 Construction Tips 2 26th December 2012 01:34 PM
ESS Sabre Reference DAC VS Prism sound ADA-8XR, DAD AX24 and weiss DAC? mbl Digital Line Level 12 19th October 2009 09:48 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
