Go Back   Home > Forums > Source & Line > Digital Line Level
Old 22nd April 2014, 07:47 PM   #1
Default ADC kits? Analog input SPDIF output? Anything?
I'm considering a few different options for an upcoming project and I might need a 24-bit audio analog to digital (SPDIF output) stage, if one is available.
Is there anything out there these days that is available as a pcb/kit?
Old 22nd April 2014, 07:53 PM   #2
Eldam is offline Eldam  France
You mean a SPIDF input stage for a DAC board ? Or you need really an output with spidf for a streamer e.g .
twistedpair audio make a device which works in the two direction if I remenber.
Sureelectronics has a good module with WM8804 with many switch (16 or 24 bits, hardware/software mode, slave/master, spidf chinch and tolinsk)
Old 22nd April 2014, 08:29 PM   #3
ADC as in "analog to digital converter". Analog R,L input; SPDIF output. 24-bit, minimum 48kHz.
Twisted Pear does not seem to offer anything like this from what I see on their web site.
Can you please link to such a product if you identify one?
Old 22nd April 2014, 08:40 PM   #4
feds27 is offline feds27  United States
TI PCM4222EVM ADC evaluation board.
Old 22nd April 2014, 08:44 PM   #5
ok : spidf to I2S (check if your dac chip is right, left justified...)
AA-AB41133 is the ref of the device, I bought two I month ago but it's not state of the art because connection between the boards add jitter : you better go if NOS with the Ian Canada FIFO boards (expensive but SOTA)
here fore sureelectronics for few bucks : CS4334 IIS/I2S Decode Board HP amplifier D/A WM8804 S/PDIF Converter Codec DAC_Accessories_Audio Amplifier and other Audio Boards_Audio_Sure Electronics' Webstore
Old 22nd April 2014, 09:28 PM   #6
No. This not at all helpful... that is a DAC (digital to analog). I don't want that.
ANALOG input. DIGITAL output. One single board, please.
Old 22nd April 2014, 09:31 PM   #7
Thanks, that would work but it is $150...
I was hoping that maybe there was a little $50 module I could buy... maybe not.
Old 22nd April 2014, 10:22 PM   #8
$50 module? I doubt it... I would rather choose to spend the 150 for EMU 0404 - 24/192 DAC/ADC and working!
Old 22nd April 2014, 10:42 PM   #9
OK, thanks for your opinion. Your needs seem different than mine.
I am looking to integrate this into a project I am building. It will be built into an enclosure with other boards. I don't want or need a "finished" product in its own case with its own power supply, because I will just have to disassemble it.
I am looking for a populated pcb or kit that would make a good A-to-D converter for $50.
Old 22nd April 2014, 10:50 PM   #10
On the link for the price you have two boards : one is what you need and what I bought alone (without the dac) one month before. I gave you the ref as well you may be find the standalone device in the web site ... it is a little n'importe quoi inside ! 18 bucks !
If you take time twice, you have a description on the link on the devices, the spidf module is the second description.
No merci pas de quoi
PS you give the dac boards to a friend or you practice training with it for interconnect (mine spidf was bought alone !)
If you use the SPDIF/coax output of your DAC, and plug into the SPDIF/coax input of ag8908 Digital Line Level 6 27th March 2014 11:11 PM
ES9012 & ES9018 I2S input = half level analog output? Angelm Digital Line Level 0 17th May 2012 11:09 AM
Digitally controlled analog Input/Output stereo audio processor tolaemon Chip Amps 3 17th January 2011 09:08 AM
4 spdif input adc? paleorama Digital Line Level 6 10th December 2010 05:56 AM
looking for ADC with spdif out. humbug Chip Amps 4 20th May 2010 05:52 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
