Signalyst DSC1
Signalyst DSC1
Old 22nd June 2018, 06:22 PM   #921
mcluxun is offline mcluxun  United States
Originally Posted by Vit123 View Post
Yes, you need +5V (Left and Right channel, internal or external) and 3.3V (external) to power triggers.
I see, to work with Cronus I will have to use 3.3v from Cronus side.
Old 23rd June 2018, 10:13 AM   #922
pistollero is offline pistollero  Portugal
The only measurements I've seen was done by Jussi Laako with DSC 2.5. His recommendations, based on measurements, was DSD256 as a "sweet pot" for DSC 2.5.
With HQP I've tried DSD256 and DSD512. My opinion (quite subjective):
1. DSD512 is better then DSD256 with the same filter+modulator. The difference is not big, but quite noticeable, even in blind tests. More "analog" sound, I'd say.
2. Full-length filters in HQP (poly-sinc-xtr (-mp), closed-form, poly-sinc (-mp) ...) is MUCH better then -2s or -shrt (short) filters. The difference is audible at once and very big.
So, the reasonable solution is in using poly-sinc-xtr (-mp), closed-form, poly-sinc (or other full filters) in DSD256. Very high SQ.
My old I7-8700 with fast DDR4 did it (computer cost ~ 1500 USD). Don't forget SoC as NAA. I am with Odroid C2 for now.
To handle DSD512 with poly-sinc-xtr (-mp) and closed-form you'll need much more power. Cost will be 3 times more.
If you won't invest to a new computer, try offline upsampling by using Saracon (up to DSD128) or AUL converter (up to DSD1024). I slightly prefer the last one.
Aleksey Galkin says that has got a very good results with special version of foobar + sox resampler + ASIO Proxy.
But bear in mind - all are very subjective
Hello Vit,
what about the modulators? any subjective perceived difference between then??
Old 23rd June 2018, 04:27 PM   #923
Vit123 is offline Vit123  Russian Federation
Signalyst DSC1
Originally Posted by pistollero View Post
Hello Vit,
Yes, modulator choiсe is also affect. Not so big as filters, but quite noticeable.
Mostly I use DSD7 256+fs, sometimes AMSDM7 512+fs.
GB DSC Signalyst v2 DSD DAC
Old 23rd June 2018, 07:33 PM   #924
phi112358 is offline phi112358
phi112358's Avatar
"I saw a few people talking about memory speed being important for this project and dsd. I just learned the other day that formatting memory sticks and hard drives with the largest block size increases read and write speeds and after trying it (64kb block size instead of standard 4kb) it has a significant effect. Minimum file size is 64kb however, or whatever block size you use."
that was my quote earlier. Well I dont want to be responsible for anyone else having to go through what I did, So that is the purpose of this update. I do have compassion when it comes to others loking their life's music collection or even one album.
Well it certainly increases speed, using max block size and since the block size determines the min file size, and redbook files are large, it sure makes sense not to divide them up into 4kb blocks with metadata surrounding each 4kb block, using space and adding innumerable operations to file reading, writing, search, processes.
OS files, often <4kb, are best stored on an HD partion preformatted to standard block size format due to block size being min filesize, hence only my two user partitions used NTFS 64kb block size.
So as I often install linux to the system partion, I installed Windowmaker on Debian.
Even after setting the Hard drive info and both ntfs (64kb block size) were detected, they could not be read.
Took ownership, edited internal HD addresses, even installed more NTFS utilities.
So I invoked testdisk, a lower level scan tool, and it complained of missing sectors.
With Block size higher, a partition of music will require less space on the hard drive and read and write quicker.
So even testdisk was built to locate files of standard block size.
Its error cited missing sectors for each user partition. (since big files stored in 64kb block size use less space, the data content did not match the amount of space it was expected to occupy.
I tried recuva after reinstalling windoughs and that probably looks for 4kb blocks because it found nothing.
Win did recognise the other music partition which uses 64kb block size after reinstall, as that had never been scanned and fixed by any linux program
So 64kb block size works best in a windows only machine if NTFS is the file structure you use.
I have not tried raising the fat32 blocksize to 64 kb but will soon.
Also need to explore ext4, btrfs, and their structures.
Well, TTL for Audiophile linux.
I built that OS via shell with netw,,, Arch Linux.
Throughout the years having lost a lot of data due to hd failure and viruses and mistakes I made, my arch audiophile linux HD with all my losslesss music has always retained every file. Lost my collection five or seven times on various mainstream distros, even Avlinux. Maybe its bc during install I only build it out of a couple dozen programs and its only a local jukebox, never online. How would one accidentally erase everything on a computer which lacks absolutely any software which can perform that function, and does not use the net?
Btw, Audiophile linux really seems to be a world apart from others with its realtime kernel and absence of power hungry processes, which can affect the audio section and create voltage fluctuations, produce rfi within the computer, which can be picked up and carry through to the audio stream it outputs.
My laptop remains at 2-5% of max state at all times on audiophile linux.
I can hear a massive difference and will never repurpose that lcd-less laptop again
Old 24th June 2018, 08:57 AM   #925
ppy is offline ppy  Russian Federation
ppy's Avatar
We talked about the speed of memory - RAM.
The speed of the storage system (HDD, etc.) does not matter.
Old 24th June 2018, 05:49 PM   #926
barrows is offline barrows
phi112358 said:
"My laptop remains at 2-5% of max state at all times on audiophile linux"
For DSC 2.6 you need to serve up DSD 256, your laptop will be working a lot harder to do this! Are you planning to oversample all your files offline and then add them to storage as DSD 256 or???
Old 24th June 2018, 09:04 PM   #927
One reason I stopped visiting computeraudiophile.com is computer black magic like this.
Old 24th June 2018, 09:08 PM   #928
Hello all, i have been listening carefull to my dac.. on the last 3 days and i have say i am really impressed with the quality of the music i m earing..
I m using signalyst and rpi3 as naa with lps.
I ve listened to a lot of dacs. Akm, cirrus, ad1965, pcm1702/4.. with valves, with opamps (almost every opamp) etc..
This dac is very good.. unfortunaly i need a better pc to use better filters and to do dsd 512.
The sound is analog, clean an rich full of details...
this is my subjective opinion ....but i would like to share it.
My fully respect for pavel and all involved in the production and fine tunning of this "no dac".
Old 25th June 2018, 11:11 AM   #929
Signalyst DSC1
+1
Old 25th June 2018, 12:07 PM   #930
a333bt is offline a333bt  Slovenia
+1
Signalyst DSC1Hide this!Advertise here!
