Signalyst DSC1
Signalyst DSC1
Old 2nd May 2017, 06:11 PM   #481
barrows is offline barrows
Default Speed switching...
Originally Posted by ppy View Post
Transformers are connected directly to the resistors.
Bruno Putzeys Mola Mola DAC, while quite different from the DSC 1, uses shift registers as the final final (acting as FIR filter I think) stage, on a single bit input at very high rate. This DAC, if you believe Mola Mola's published measurements, has a superbly low noise floor. Any thoughts on this? Would not limited speed of the shift registers matter here as well?
BTW, if I am remembering correctly, the NXP chips have better claimed performance (on the data sheet) than the TI chips, are you using the TI chips supplied with the Chinese DSC 1 Balanced kit?
Old 2nd May 2017, 08:59 PM   #482
ppy is offline ppy  Russian Federation
ppy's Avatar
That's measured with -0db level without AK4137. The DSD128 dsf file is converted from WAV by the saracon program.
Found an error in his measurements. The EMU was not properly calibrated.
The reality was not so beautiful.
  • -1db THD 0.0037%
  • -5db THD 0.0014%
  • -10db THD 0.00028%
  • -20db THD 0.0007%
I used the ones that were in the сhinese kit - TI 74ahct595.
I tried in the unbalanced version of Fairchild 74VHC595M. Same for speed but more noise immunity (on the data sheet). The noise from Fairchild increased.
Old 3rd May 2017, 02:25 AM   #483
Signalyst is offline Signalyst  Finland
-1db THD 0.0037%
  • -5db THD 0.0014%
  • -20db THD 0.0007%
Doesn't look too bad to me. This of course includes also the ADC's THD+N.
As usual with many DACs/ADCs, best performance in this setup seems to be at about -10 dB point. 0.00028% THD+N gives -111.06 dB (equivalent of about 18.5 bits) level which is probably closest to the background noise. Enough for most recordings...
PSU noise level is critical. One could also experiment with something like 2.2 F OSCON + 100 nF X7R/C0G in parallel on each 595's PSU pin.
Not sure how much a transformer will let the ultrasonic noise through, would be good to check.
Old 3rd May 2017, 07:02 AM   #484
zenelectro is offline zenelectro  Australia
zenelectro's Avatar
Originally Posted by Signalyst View Post
[/LIST]Doesn't look too bad to me. This of course includes also the ADC's THD+N.
It's worth noting that any OP voltage swing on the resistor network will cause
distortion. If you use a conventional virtual gnd I-V linearity will improve.
Having said that, it may not sound better!
Also to get a really accurate measurement, it's best to use a notch filter to attenuate fundamental.
ADC for measurement will then be much less stressed.
Old 3rd May 2017, 07:04 AM   #485
bavmike is offline bavmike  Canada
Banned
This project looks like a lot of work. I wonder if the end result will pay off?
Old 3rd May 2017, 08:01 AM   #486
ppy's Avatar
For every 595 installed ferrite beads+tantalum 10F+0.1 X7R. PSU - Two modules TPS7A4700 on main PCB.
Certainly! DSC1 is now my main DAС. And I do not want to change it to something else. I like its analog/intelligent sound very much.
Many thanks to Signalist for this wonderful project!
Old 3rd May 2017, 08:05 AM   #487
Banned
I would love to compare it with my DSD DAC. I decided to offer our commercial Purestream DSD DAC as a kit for DIYers to build. I'll be starting a thread on it soon. There will be all sorts of ways of customizing the unit for different sound and budgets. It's specifically designed to use software SRC/SDM just like the DSC-1, only uses a different strategy. All SMT components will be soldered on the boards already. It will be a very simple kit to build for anyone at all skill levels.
Old 19th June 2017, 06:25 AM   #488
oscord is offline oscord
Originally Posted by jborden View Post
I'm not sure where Amanero etc are in this. I've set mine aside as I'm working on the direct Ethernet->DSD route.
Is there anything to share yet in that regard please? Been looking to connect DSC1 to network storage via ethernet for a while
Can't wait to see your design somewhere on ebay or alibaba!
Old 21st June 2017, 02:58 PM   #489
jborden is offline jborden  United States
<JAB.R>
Signalyst DSC1
In the short(er) term I've had terrific success using the solid-run ClearFog Base as an NAA accepting Ethernet (including fiberoptic Ethernet) input and output via USB to the DAC. Its cheap.
My own project now awaits my completing a Linux device driver which is not my forte but coming along. It is very similar to the Merging Zman board, employing a hybrid ARM/FPGA (zynq). Won't appear on ebay
Old 16th August 2017, 08:54 AM   #490
ondrejk53 is offline ondrejk53  Slovakia
Hi, did you discover some white noise during playback? Thanks. Ondrej
Signalyst DSC1Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
