Jitter
Jitter
Old 17th March 2014, 09:04 AM   #1
mBox is offline mBox
Default Jitter
Not sure this post is in the right section ...
However If I connect a Music Player which streams the songs through my NAS - will this reduce jitter in conjunction with my DAC in opposite to just sending the signal directly from my HDD to the DAC?
Any thougths on this greatly appreciated. thank you.
Old 17th March 2014, 09:55 AM   #2
Julf is offline Julf  Europe
I think we need a bit more information. What DAC? How is it connected, and to what? When you say "sending the signal directly from my HDD to the DAC", are you saying that you have a DAC with a controller that can read a hard disk directly (using USB, I assume)?
Old 17th March 2014, 11:39 AM   #3
Okay. My setup is a NAS with UPnP where the music is stored. I have connected a RaspberryPi to my NAS (through ethernet). My BRIK DAC is connected through USB to my Raspberry running MPD.
DAC (USB) --> RASPBERRY --> NAS. My DAC is doing all of the decoding completely bypassing the onboard sound of the raspberry. All the Raspberry does is buffer 50% of the song before playing it.
Old 17th March 2014, 03:06 PM   #4
There should not be a significant difference in jitter.
Old 17th March 2014, 03:18 PM   #5
Copy that. So it doesn't really matter in terms of jitter if I'm accessing the files through ethernet with flow-control or if I'm accessing the files directly on the hard drive of the nas.
Old 17th March 2014, 10:16 PM   #6
TNT is offline TNT  Sweden
http://www.diyaudio.com/forums/digit...ac-system.html
Old 18th March 2014, 07:20 AM   #7
No, doesn't matter. Both the hard drive interface and the ethernet connection are fully buffered and independently clocked, and the only possible influence on jitter is the CPU/IO load they cause, and that is rather theoretical (and the load is pretty similar in any case).
Old 18th March 2014, 08:32 AM   #8
Cool
Old 18th March 2014, 08:00 PM   #9
Could you describe your whole chain? What interface does your DAC have?
Old 18th March 2014, 11:06 PM   #10
NAS [Ethernet] --> Raspberry [USB] --> BRIK DAC [AUX] --> AMP
http://webbuilder3.asiannet.com/ftp/...0Converter.pdf
6moons audio reviews: Brik Audio DAC and integrated amplifier
I'm using kernel streaming on the Raspberry. The stream's supposedly untouched.
JitterHide this!Advertise here!
generate jitter test signal and measurign jitter using AP2? BJAMR Digital Source 11 1st November 2010 02:07 PM
Jitter and all that fixerfrasse Digital Source 13 15th January 2007 06:30 AM
Data Jitter Versus Electrical Jitter? 300_baud Digital Source 8 16th July 2004 07:59 PM
