Jitter
Jitter
Old 20th March 2014, 11:55 PM   #21
mBox is offline mBox
Ok. How do I slave the source to the DAC?
Old 21st March 2014, 12:04 AM   #22
Eldam is offline Eldam  France
Banned
Need an output buffer then an input buffer for the clock line or does it need jus a maximum inchees/cm line between the master clock and the slaved device ? speed clock need to be adapted for the slave ?
Old 21st March 2014, 08:22 AM   #23
Julf is offline Julf  Europe
To start with you need a source that can be synchronized to an external clock (this is normal on pro gear). What is your source?
Old 21st March 2014, 09:14 AM   #24
Thanks. I'm using RPi as source - sending the signal to my DAC
SOURCE (RPi) -------USB------> DAC
Old 21st March 2014, 09:42 AM   #25
OK, but that is asynchronous USB, so there is no need to synchronize the clocks. The clock synchronisation is an issue only for connection methods (such as S/PDIF) that don't have a flow control mechanism.
Old 21st March 2014, 03:37 PM   #26
Banned
Julf,
If the master clock is the one of the main DAC : do we need to adapt the frequency clock with dividers to feed the emmiter spidf chip in the source side ? Let say with a RPI as well (it's just to understand, have 2 SB Duet, but don't want to break those device with my bad skill).
I have maybe please a more general question about the clock wires: which is the "worse" solution at same length of cables if we can put the two devices close enough together):
1- spidf feeding with buffers (and/or multiple serie chips or passive components in serie)
2- High jack the I2S from the source if possible ? Of course with a flat SgSgSgSG wire : S(ignal)/g(round) ?
My actual understanding is 1) is a good enough solution but 2) a better one as the clock has its own non shared line (but doesn't work if length is > at something like 5 cm) ?
Old 21st March 2014, 03:46 PM   #27
Originally Posted by Eldam View Post
If the master clock is the one of the main DAC : do we need to adapt the frequency clock with dividers to feed the emmiter spidf chip in the source side?
I would definitely not start to fiddle with the spdif clock unless it was clearly shown that there is an issue with excessive jitter.
Old 21st March 2014, 03:56 PM   #28
Banned
thank you,
Ok, my understanding with your answer is a spidf receiver can work with a large bench of frequencies.
It was as just more a theoric question as I'm planning to play with old miltibit dac chips. But have two SPIDF Sure electronics spidf W8804 receiver. Those devices are nice for fools like me : very versatil : you can switch off the hardware mode... But was very addict to the Ecdesign thread one year ago; the parts with the masterclock and buffers was a little hard to understand and I gave up...
Old 21st March 2014, 04:02 PM   #29
Definitely!
Old 31st March 2014, 10:23 AM   #30
Does anyone know a good (cheap) USB to S/PDIF converter?
JitterHide this!Advertise here!
generate jitter test signal and measurign jitter using AP2? BJAMR Digital Source 11 1st November 2010 03:07 PM
Jitter and all that fixerfrasse Digital Source 13 15th January 2007 07:30 AM
Data Jitter Versus Electrical Jitter? 300_baud Digital Source 8 16th July 2004 08:59 PM
Copyright ©1999-2017 diyAudio
