My DSP/DAC Build - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 14th March 2014, 09:57 PM   #11
Send a message via MSN to Adrculda Send a message via Yahoo to Adrculda
A few changes to the DSP diagram...
Now I2C and SPI control is possible and added a few "future proof" changes.
Still working on the DAC, but will probably get it done by tonight.
Adrian
Old 15th March 2014, 04:47 AM   #12
Finished with the DAC and even drew up a filter section as well.
Now I'm doing a bit of research as I'm still unsure whet ever i want to use I2C or SPI...
Adrian
Old 15th March 2014, 05:55 AM   #13
Adrian,
Looks like you are using Altium for this...
If you want to dig into what I did using an ADAU1442, all the files are in my blog. I did take a somewhat less enthusiastic approach to I/O - and only implemented four pairs of stereo outputs (though adding more would be a doddle).
The most tedious part of using these devices, in my mind, is writing all the code for the user interface, and especially initialisation and loading. There are bags of registers to set right, and I really hate the documentation for these chips - it does not make it easy! Take a look in the code I uploaded - some of the initialisation stuff is a bit arcane!
Old 15th March 2014, 06:12 AM   #14
Thanks googlyone...
Yes, I'm using Altium and it wasn't hard to to get the chip imported into the part library as AD offers the model right on their site. All you have to do is install Ultra librarian and then use the BXL file they provide. Once you run the file through the program it creates an Altium friendly device that can be used.
My goal with this board is overkill, I know...
BUT what I want is to be able to MAP 20 Channels in any way I can dream it. Silly if you think about it, but in doing so it makes this probably the most flexible configuration in the DIY market. with any kind of filter and EQ's at your fingertip ( if setup properly even RTA isnt out of reach ).
As the software goes...
Its my acheeles heel and that's why I picked an Arduino based processor as the code is easier to write and interface over the other obvious uC out there. I'm also on the Analog EngineerZone forums and been poking around and trying to soak up some knowledge on this topic.
Adrian
Old 15th March 2014, 07:08 AM   #15
Here's a quick road map:
DSP1:
BLCK0/RLCLK0 -> BLCK2/RLCLK2 : I2S Input From Digital Input Board ( DIX9211 )
BLCK3/RLCLK3 -> BLCK5/RLCLK5 : I2S Input From DSP2
BLCK6/RLCLK6 -> BLCK8/RLCLK8 : I2S Output To DSP2
BLCK9/RLCLK9 -> BLCK11/RLCLK11 : I2S to Digital Output Board ( DIT4192 )
DSP2:
BLCK3/RLCLK3 -> BLCK5/RLCLK5 : I2S Input From DSP1
BLCK6/RLCLK6 -> BLCK8/RLCLK8 : I2S Output To DSP1
DSP's will feed the DAC's Through the Serial Data Buses as follows
DSP1 -> DAC1: SDATA0 - SDATA4
DSP2 -> DAC1: SDATA0 - SDATA4
DSP1 -> DAC2: SDATA5 - SDATA8
DSP2 -> DAC2: SDATA5 - SDATA8
Clock will be supplied from a Crystek CCHD957 ( Custom - 12.288MHz ) single which will feed a LMK00334 Fan out buffer which in turn will feed every chip.
Again, I'm not worried about the hardware as much I'm worried about the software
Adrian
Old 16th March 2014, 07:01 AM   #16
Change of plans...
Instead of bloating the board with more parts I decided that it needs to slim down.
So DSP1 and DSP2 will have their own clocks and DAC1 and DAC2 will use their clock outputs. Also after reading i realized that the 1445 wasn't the one I was after but the 1442 was, with that being said i bought 8 pieces from AD. I will used the 1445 for now but eventually switch over to the 1442.
Still working on changes for each block as i go along including the slave settings.
Adrian
Old 16th March 2014, 08:10 AM   #17
Found some info on I2C coms on Arduino Due ( which in one way or another is what I'm using ) HERE
Info was pulled from this THREAD
Adrian
Old 17th March 2014, 10:40 PM   #18
That's the block diagram.
Still missing a few items though, but getting very close to starting board lay out.
Adrian
Old 18th March 2014, 02:21 AM   #19
Compiling the project in altium proved easy enough...
But found a but load of errors and specially since I copied the DAC 1 to DAC 2 and DSP 1 to DSP 2, i kinda copied the unique indentifiers as well.
So, now i have to go back and rename every one of them :/
Back to work I guess!
And i was getting happy that I'm getting close to starting to lay out the board...
Adrian
Old 19th March 2014, 06:09 AM   #20
Ugh.. what a hassle LOL
This isn't as much fun as i thought it would be, nor as easy.
Adrian
mini dsp as high end dac keager miniDSP 1 3rd June 2013 09:33 AM
Li-ion powered wireless DSP/DAC? jalyst Parts 0 13th October 2009 07:42 AM
Dose any one has experince about the implementation DSP in DAC, like Theta Did? lanyuflying Digital Source 2 20th January 2008 12:12 PM
DSP Starter kit w. ADC/DAC jensenstefan Swap Meet 0 28th February 2007 01:34 PM
DSP and DAC noise nFORCE Digital Source 4 29th April 2003 03:18 PM
Copyright 1999-2017 diyAudio
