USB Input Switch
USB Input Switch
Old 26th February 2014, 05:57 PM   #1
ungie is offline ungie  Canada
Default USB Input Switch
Hi everyone,
I'm in the process of designing a simple USB DAC based on the PCM2707. I would like to be able to have two USB input jacks and switch between them. I could use a 4-pole switch, but I would like something more elegant, maybe a MUX IC along with a push button to control the switching. I'm mainly concerned about using something that will not compromise the data integrity. I'd appreciate any ideas.
Thanks!
Old 27th February 2014, 09:00 AM   #2
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Wouldīnt you managae that with a 1 pole swicth?
You donīt have to switch the +5v and the groundīs
just the data stream.Or am I wrong?
Regards Åke
Old 27th February 2014, 11:16 AM   #3
AAK is offline AAK  United States
Hi ungie,
If you're worried about signal integrity a high speed relay will do the job.
Invalid Request
I use these relays to switch between two USB inputs and it works great.
Hope the info helps.
Best regards,
Al
Love when you can, Cry when you have to, be who you must, that's part of the plan.
Old 27th February 2014, 11:20 AM   #4
Not sure if the link worked. The digikey part number is PB1094-ND.
Old 27th February 2014, 05:33 PM   #5
Thank you.
Because this is a DPDT relay, I'm assuming you are using two of them in order to switch +V, GND, D+, and D-?
Old 18th March 2014, 06:18 PM   #6
My understanding is that V+ MUST be switched as well as it is connected to the HOST pin on the PCM2707. You cannot have the V+ supplies from both USB devices connected together, and I suspect that you would not want to have those grounds tied together either. I'm really trying to duplicate the identical behavior of unplugging and plugging in between two devices. I'm surprised there isn't a good chip for this application...probably is but I haven't found it yet.
USB Input SwitchHide this!Advertise here!
IC with SPDIF input to USB or 1394 (or with HDMI input for audio stream) VickHard Digital Source 2 26th March 2010 02:17 AM
Input Switch? markw51 Tubes / Valves 0 23rd December 2006 12:08 PM
Can I switch between two input receivers? riotubes Digital Source 20 23rd August 2005 06:11 PM
input switch for BOSOZ Gabrielshorn Pass Labs 1 19th September 2003 05:57 AM
Relays as input switch? Nisbeth Solid State 26 28th October 2002 06:12 PM
