Very high I/V resistor in Sony dataprocessing IC.
Old 13th February 2014, 07:29 PM   #1
Shoog is offline Shoog
Shoog's Avatar
Default Very high I/V resistor in Sony dataprocessing IC.
I am considering building an experimental CD player using a salvaged transport from a portable CD player. It uses an obscure Sony Data processing chip with a built in 1bit DAC. On the chip it has a current output and then an internal OPamp for generating a voltage output. However the sttange part is that on the suggested implementation it has a network of I/V and feedback resistors with values of 12K. The current output seems to suggest that its capable of 4mA signal output - but this is difficult to interpret from the datasheet and doesn't seem to fit with a 12K I/V resistor.
I want to put it into a tube output stage and use just the current output with a resistor load - but This would suggest a value of I/V more in the range of 100's of ohms.
I am new to this, but it doesn't make much sense so far.
Shoog
Old 13th February 2014, 07:39 PM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
and datasheet is ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 13th February 2014, 07:49 PM   #3
Shoog's Avatar
Tricky that since I only have a sister datasheet from the same period, and even that was a bitch to find. The datasheet i have is for the CXD2548R
http://pdf.datasheetcatalog.com/data...y/a6800323.pdf
Page 8 has the output data and page 12 has the suggested output network.
I know your going to tell me this is a pile and not to bother - but this is a no cost experiment to see if its worth seeking out a decent transport to do the same.
Shoog
Old 13th February 2014, 08:11 PM   #4
Zen Mod's Avatar
I can see 1V15 and 8K on p.13 , but I can't see 4mA anywhere on page 8
Output voltage (3) sez (-0,28/+0,36)mA
Old 13th February 2014, 08:18 PM   #5
Shoog's Avatar
I saw the output voltage 3, but wonder why there is an output voltage 1,2,3. As I said this is new to me and it really doesn't make a lot of sense yet.
8k is the min. load resistance, which is about what you would get when all of the output network were summed together.
Still if that is correct then the calculated output voltage would be -2.24V to +2.88V which would be a reasonable output voltage.
Its a workable system - but certainly far from typical for a current output DAC.
Shoog
Old 13th February 2014, 08:29 PM   #6
Zen Mod's Avatar
see - number in brackets is referring to applicable pins
so , (3) is current at those AIN pins , where 12K resistors are connected and that's , in this moment , still pretty much black box to me
however , -2V24/+2V88 is pretty decent output voltage
even if figure of 8K as min load is suggesting that LOUT pins aren't current output pins , but voltage ones
Old 13th February 2014, 08:38 PM   #7
Deafer is offline Deafer
Looking at your data sheet, page 12, the circuit with the 12k resistors etc is a low pass filter circuit for measuring distortion and noise figures at 1 kHz. It is not the suggested circuit for normal operation. Normal operation seems to be the page 12 bottom diagram, which seems to be a direct feed with levels given on page 13, top.
Old 13th February 2014, 09:22 PM   #8
Shoog's Avatar
The same circuit is suggested as the output configuration into the final load later in the datasheet, so those figures are the recommended one's.
Shoog
Old 14th February 2014, 07:45 AM   #9
Calvin is offline Calvin  Germany
Calvin's Avatar
the Datasheet specifies Lout1 and Lout2 as voltage outputs of the internal OPamps.
Chapter 3-11, Diagram 3-12 on page73 clears up things.
It reads LPF-Block and that it is.
The Opamp between the Lout and Ain pins is working as a unity gain filter block.
As such a variation in the feedback resistors varies the filter´s response but not the output amplitude.
The second OPamp feeding into Aout generates a DC Reference voltage.
It´ll probabely work as DC-Servo here.
So no hint of a current output at all.
I/V conversion is fixed inside the Chip and fixed is the output volage level.
jauu
Calvin
Old 14th February 2014, 09:37 AM   #10
Shoog's Avatar
Cheers for the clarification.
Not really a great candidate then.
Shoog
Very high I/V resistor in Sony dataprocessing IC.Hide this!Advertise here!
Sony CXA1213S IC wanted limono Swap Meet 3 19th March 2012 02:00 PM
Wanted Sony BX269A IC / TA-8650 zedrider Parts 0 21st February 2009 06:40 AM
Sony BX-269A IC wanted zedrider Parts 0 18th February 2009 04:45 PM
use sony s-120a IC in place of ta-100w chiefkenny01 Solid State 1 4th April 2008 04:14 AM
IC resistor ladders...has anyone used them? Spasticteapot Parts 0 6th November 2006 02:41 AM
Copyright ©1999-2017 diyAudio
