IIR cascaded with pseudo-inverse IIR, is phase also restored? - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 10th November 2013, 12:46 PM   #1
OllBoll is offline OllBoll  Sweden
Default IIR cascaded with pseudo-inverse IIR, is phase also restored?
Hello there,
I'm considering using cascaded DSP where I in the first unit apply a rising +18 dB in between 20 and ~ 80 hz to simulate an OB. This unit (MiniSHARC) also has a compressor which combined with the 18 dB slope should if I understand correctly be able to limit at xmax.
The second unit will probably reduce low end gain somewhat, thus in the frequency domain inversing the slope done by the first dsp and fit for the actual driver and enclosure and my question is this:
How is phase affected by doing this? Will the phase response only be dependant on the end result after EQ or will doing this distort the phase more than if I only used filters to fix the actual response?
IIR-based crossover: no thanks! steph_tsf Digital Line Level 3 30th July 2012 10:21 AM
IIR vs FIR: opinons? cuibono Multi-Way 21 29th August 2009 10:07 PM
IIR filters type 1 or 2 what is best? JensRasmussen Digital Source 14 22nd April 2004 09:23 PM
FIR or IIR filters in matlab theChris Everything Else 5 16th March 2004 04:32 AM
need help with IIR filter theChris Digital Source 0 13th March 2004 12:47 AM
Copyright 1999-2017 diyAudio
