Build thread - building the Subbu DAC V3 SE
Old 11th February 2014, 10:15 AM   #731
bcmbob is offline bcmbob  United States
Stixx inspired me to combine the V3 and an 02 headphone amp I'm using as a pre for some Pass amps. Haven't done any extended listening, but the pair sounds great together.
What came to mind was adding an 1/8" (the 02 is all 1/8") switching convenience jack for dual use in a final chassis build. Two questions:
1. The DAC maintains separate grounds on the output. Does combining them degrade the signal in any way? JP/Subbu must have had a reason to keep them discrete.
2. Is there an advantage to switching between RCA and barrel compared to just leaving both active? Does the V3 see the the open set as some kind of leak?
Barrel Audio Connector.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 13th February 2014, 04:12 PM   #732
Eldam is offline Eldam  France
Banned
HI
I received my spare parts this morning and just populate the faulty ldo reg, no problem with the 50 mhz FOX XO... it sings like a "renard" !
The music flows, everything is allright. No Ziiiigouilliiiii or crips can be heard with the speakers !
Music feeling is good after few tunes. It's very "natural" , easy, highs are sweet and not glitchy. Timbres, tones are true. Maybe the soundstage, imaging are a little confused. Maybe violins in highs could be better but it's the best thing I've heard at home !
Will come back after different expensive tests, few tweaks with PS and caps to setup with my environment. Sure the sound can be improved and I will write a little listening reviews with the JG buffer (still waiting for the BOM to come from Mouser... because the Fastron inductor out of stock)
Thank you JP, Subbu, and others for tips. It helped me a lot. Beautifull dac? Yes...A "bravo" for the design and optimisation at such a low price.
regards
Eldam
Old 14th February 2014, 08:21 AM   #733
cedricb is offline cedricb  Europe
received my fully built PSU/DAC from korben; it's teeny-weeny!!
...I'm looking at a teeny-weeny chassis with a BNC, 2 RCAs and power jack at the back; anything ready available? :-)
Otherwise for a toslink connection (GP1FAV51RK0F); what do I need for the bypass capacitor (0.1 uf, no SMD please) on the receiver module? ...capacitor choice is a bit like black magic to me!
What's the general capacitor type/brand to use across the VCC/GND on analog or digital ICs? ...os-con?
Old 14th February 2014, 05:51 PM   #734
atupi is offline atupi  Romania
In your case can choose a ceramic one, leaded if you like.
Rega RP-1/Simplistic RIAA by Salas/ DCB1 clone/ MyRef Fremen Edition/FC-100/ XTZ 99.26 MkII speakers
Old 16th February 2014, 09:30 AM   #735
fordgtlover is offline fordgtlover  Australia
I have finished my build. It's got all recommended parts apart from the WIMA 4.7 in C35. Mine has the BC128 SAL-RPM.
I'll get it up and running in the next few days and report back on how it sounds.
Old 16th February 2014, 09:57 AM   #736
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
It won't work as it is now as you're missing all beads...
Good looking build except for one thing: the solder joints of the ES9023 seem very brittle. It even looks like it hasn't been soldered.
It's only audio. Member of the non modular PCB design committee
Old 16th February 2014, 10:52 AM   #737
Indeed. I've left the beads off so that I can check voltages when I power it up.
I had more solder on the pads than I wanted, so I wicked some away. Admittedly, I did wick a bit more away than I had intended. While the pads are now only lightly tinned, the leads still have reasonable fillets so I decided not to redo them. I checked them very carefully with a magnifier.
Old 16th February 2014, 09:53 PM   #738
audionootje is offline audionootje  Netherlands
Default Another SUBBU DAC singing
Hi All,
Just to let you know my build of the Subbu dac is working.
I'm enjoying the dac at the moment via my stax headphone whilst typing this message.
Thanks to Subbu & Jean Paul (and Korben for the component group buy).
Old 16th February 2014, 10:25 PM   #739
jean-paul's Avatar
OK, another dutchman having a good DAC. Let us know how it sounds after a few days.
Did you replace the 3.3 V reg for a 3.6 V one ? If not please be aware that the 130 kOhm must be changed if you keep the DAC running on 3.3 V.
Reasonable is not a good word when building quality gear. They really look like dry joints. Resoldering would be a wise thing IMO or it must be that the chip has seen the soldering tool too many times now. If so it is maybe better to leave it like it is.
Old 17th February 2014, 08:06 AM   #740
Originally Posted by jean-paul View Post
...snip
When the designer suggests for a second time that I should touch up my solder joints, it's wise to pay attention
Shiny new solder joints
Build thread - building the Subbu DAC V3 SEHide this!Advertise here!
ES9023 / WM8804 S/PDIF "Subbu DAC V3" GB Interest korben69 Group Buys 1032 7th March 2018 04:57 PM
"Subbu DAC V3 - ES9023/WM8804 SPDIF & Power Supply PCB" Group Buy unixdeveloper Group Buys 1042 30th April 2016 07:17 AM
WTB V2.6 PCB for ES9023 / WM8804 S/PDIF DAC –SUBBU DAC grufti Swap Meet 0 26th November 2012 05:51 PM
V3 tube-lover SE TDA1541 DAC bakus11 Swap Meet 3 21st April 2010 05:30 PM
SE - Build Thread soundengine355 Solid State 6 27th June 2009 12:19 AM
