Build thread - building the Subbu DAC V3 SE - Page 10 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 16th November 2013, 06:36 AM   #91
diyAudio Moderator Emeritus
jean-paul's Avatar
Originally Posted by tofurky View Post
hi jean-paul,
on a similar subject, the united chemicon polymer caps specified for C2, C3, and C18 were OOS at both of my usual suppliers, so i took the liberty of making a substitution with a panasonic SEPC part.
APSA160ELL101MFA5G 100uF/16v 25mOhm esr
16SEPC100MW 100uF/16v 10mOhm esr
would the lower esr here cause potential resonance even when paralleled with the larger 4.7uF ceramics at C5, C7 and C19?
thanks,
-matt
Hi, I do use polymer 100/10 myself for C2, C3 and C18. No problems, also with C5, C7 and C19 in 4.7 F tantalum. The ones I got fit exactly (3.5 mm pitch) and the SEPC 100/16 are smaller with a smaller pitch (2.5 mm). They don't fit if you like shortest connection and a tidy built neat looking DAC. The 100/16 SEPC fit on the footprint for C22. I have the SEPC 100/16 but I don't use them on the V3.
With the V2.6 I once had oscillating MIC regs with ceramic caps at their outputs. in the hope that others read this: don't use ceramic caps straight after the regs !
It's only audio. Member of the non modular PCB design committee
Old 16th November 2013, 08:12 AM   #92
houghtkj's Avatar
Originally Posted by jean-paul View Post
After Gary stated that a larger value for C22 would improve matters I only could get Panasonic FM 220/10 in time to try out. No time for measuring but to my ears it sounds a tad better. Not a very large difference but still... This is still with 1 f ceramic cap in parallel.
So feel free to experiment with larger values than 100 F for C22. Gary said 470 F was his choice but the ones I could get hold of don't fit on the PCB. The Pana FM 220/10 does fit exactly.
OK, I'm confused now - I ordered 68uF SAL-RPM caps for C22 (at some cost) - Do I fit these or 100uF Polymer, or 220uF polymer or 470uF Elect. What, if anything will I lose by using the SAL-RPM's.
That said, I am very sceptical when it comes to swapping capacitors as in the past I have seen very little, if any, improvements.
Ken
If all you have is a hammer, everything looks like a nail.
Old 16th November 2013, 08:23 AM   #93
jean-paul's Avatar
Just use the SAL caps and you won't be confused. Exchanging Avccc/Vpos caps for polymer caps is done by Gary but it is not what we used ourselves. We do find that caps make a difference like for example C22 but we made a choice back then. With SAL you will have a good result and when you're brave you could try out polymer caps at your own risk. You don't "loose" something when using prescribed parts and yes they come at a cost. I still have to find free parts Wait till you have built around 25 of them, then add up what you spent !
Exactly avoiding this confusion is why you all wanted a BOM. Any deviation and chaos arises....Only the more adventurous builder tries stuff out and it will only be possible to compare if 2 or more are built. In development stage we do also try out parts , how else can we do otherwise ? So we stick to certain parts and don't bother again afterwards. Many af us don't take things for granted and want to go beyond the standard. That is fine but I now see that such info can work confusing for those that want to follow a guideline and/or are not used to choosing themselves.
With the BOM parts you will have a good working good (if not excellent) sounding DAC. For those that want to press the last % out of it there is some room for experimentation. If there are any preconceptions, beliefs etc. I would not even bother to read any info regarding modifications.
This is not going a direction I like and any statements done for improving the V3 are entirely for the person making them and I include myself in that. Any of you that likes to try out parts please do so but do not complain if results are negative. Maybe this should not be in the building thread at all ?
Old 16th November 2013, 08:31 AM   #94
houghtkj's Avatar
Just use the SAL caps and you won't be confused. Exchanging caps for polymer is done by Gary but it is not what we used ourselves. With SAL you will have a good result and when you're brave you coul try out polymer at your own risk. You don't "loose" something when using prescribed parts and yes they come at a cost. I still have to find free parts
Exactly this is why you all wanted a BOM. Any deviation and chaos arises....
With the BOM parts you will have a good working good (if not excellent) sounding DAC. For those that want to press the last % out of it there is room for experimentation. If there are any preconceptions, beliefs etc. I would not even bother to read any info regarding modiciations.
Many thanks for the sanity check JP - Excellent advice - Even to us with a high paranoia factor!
Ken
Old 16th November 2013, 08:39 AM   #95
jean-paul's Avatar
From a commercial point of view I can only encourage any builder to build 2 or more of our V3 DAC Only then one can compare stuff.
Old 16th November 2013, 10:20 AM   #96
bcmbob is offline bcmbob  United States
Are there additional boards available now, or will there be another GB style offering in the near future?
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 16th November 2013, 11:14 AM   #97
jean-paul's Avatar
Oh I really need to weigh my words before saying them. I don't know of any new GB. My guess is that Subbu needs some rest now. Of course we are busy with something new. I doubt an I2S version still is valid with so many offerings for little money. Just check Curryman's I2S DAC.... I will discuss this with Subbu.
I have confidence in our V3 to be one of the better SPDIF ES9023 devices. Just modified an O2 Joggler with Squeezeplay OS to have an SPDIF output and it is amazing how this combo sounds. Must admit that adding a 75 Ohm BNC in the Joggler is a nerve racking task but it works and the device still is unscratched etc.
Tip: O2 Jogglers are excellent replacements for Squeezeboxes ! You need to be experienced to add RCA or BNC SPDIF and to have a fearless approach to Linux...
Old 16th November 2013, 11:25 AM   #98
JP, Didn't mean to give the wrong impression. I was referring to your comment about building a couple DACs for comparison purposes. I was asking if there had been any over production of just the PCB, or if everything has been sold, is there enough interest to warrant a GB/production run for the boards only. I really like your idea of multiple builds as an alternate to pulling and replacing parts.
Bob M.
Old 16th November 2013, 11:33 AM   #99
jean-paul's Avatar
Hi Bob I did exactly understand what you are saying but I think Subbu has had his share of Group Buys for the moment, that also counts for extra production of boards. It was a one time only affair from the beginning.
Of course I am willing to let my spare PCBs go for enormous amounts of money No I won't, not everything in life is about money !
Old 16th November 2013, 11:45 AM   #100
Fine, I hear you. Subbu (and you) truly deserve some down time, and above all - high accolades an appreciation for an enormous task well done. We are all grateful for your efforts.
Bob M.
"Subbu DAC V3 - ES9023/WM8804 SPDIF & Power Supply PCB" Group Buy unixdeveloper Group Buys 1042 30th April 2016 07:17 AM
ES9023 / WM8804 S/PDIF "Subbu DAC V3" GB Interest korben69 Group Buys 1029 21st February 2016 11:20 AM
WTB V2.6 PCB for ES9023 / WM8804 S/PDIF DAC SUBBU DAC grufti Swap Meet 0 26th November 2012 05:51 PM
V3 tube-lover SE TDA1541 DAC bakus11 Swap Meet 3 21st April 2010 05:30 PM
SE - Build Thread soundengine355 Solid State 6 27th June 2009 12:19 AM
Copyright 1999-2017 diyAudio
