DSP for the Raspberry Pi
Old 21st November 2013, 10:35 AM   #11
cloudalmasai is offline cloudalmasai  Venezuela
Hi little question, this dsp can work with the I2S out of the P5 in the RPI? thanks.
Old 21st November 2013, 01:19 PM   #12
usul27 is offline usul27  Switzerland
usul27's Avatar
Yes, this works.
Old 21st November 2013, 01:47 PM   #13
Thanks, really interesting, and the Multipurpose GPIO could be used with external DACsin in the same pcb? Or the internal DACs of the ADAU1701 are good enough? Thanks
Old 21st November 2013, 02:06 PM   #14
mhelin is offline mhelin
Looks good. This is like the miniDSP (from miniDSP.com not from TI) for Rasperry Pi - the DSP is the same one. Let's hope miniDSP.com won't steal your idea (or maybe you could sell your design to them). Look for extensions for next rev. if there will be one, folks need more outputs (at least 6x or even 8x for active speakers).
Old 22nd November 2013, 09:15 AM   #15
usul27's Avatar
I had some issues with the available space on the board. Therefore not all IOs are available from the outside. But I might change this in a next release.
Old 12th January 2014, 12:29 AM   #16
Hi any news about availability?
Old 12th January 2014, 08:11 AM   #17
usul27's Avatar
Not yet. As I'm busy with the DAC and the Digital output of the Raspberry Pi, this project is on hold at the moment. I'm also thinking about replacing the ADAU1701. Compared to my HiFiBerry DAC, the DACs on the ADAU1701 are not so good.
Old 12th January 2014, 12:16 PM   #18
A OK, I think that would be the case, what DSP chip do you have in mind for replace the ADAU1701?
Old 12th January 2014, 06:06 PM   #19
PCM5142 with two Raspberry Pi P5 headers for HIFIBerry for extra output channels? Or just two PCM5142's (4 channels)+ single P5 header (GPIO output from the other 42).
Old 12th January 2014, 06:09 PM   #20
usul27's Avatar
Yes, I have the PCM5142 in mind ;-)
DSP for the Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
rdesktop, a killer application for raspberry pi counter culture Everything Else 3 7th February 2015 02:19 PM
Cheap USB- soundcard for raspberry pi knorst Digital Source 29 21st August 2013 05:13 AM
Raspberry Pi & accessories Nikitas Swap Meet 5 5th July 2013 11:47 AM
Raspberry Pi -A New DIY'ers Digital Hub? pinkmouse Digital Source 164 11th June 2013 09:21 PM
