I2S line termination on dual mono DAC - 4 or 8 resistors?
Old 24th October 2013, 11:00 AM   #1
Groundloops is offline Groundloops
Im amazed!
Groundloops's Avatar
Default I2S line termination on dual mono DAC - 4 or 8 resistors?
I'm planning the build of a WM8741 dual mono differential DAC. When it comes to the I2S line termination I wonder how many resitors to use - 4 or 8?
Old 24th October 2013, 12:27 PM   #2
marce is offline marce  United Kingdom
2nd one values would have to be half of 33R.
These are series termination and should be placed as close to the driver as possible, and really have to be matched to the PCB layout to be effective.
Other factors come into play such as receiver and transmitter impedances etc. The pics below show the effect of series termination resistors on a real signal, and how matching the value to the line gives the best result.
Old 24th October 2013, 12:38 PM   #3
Im amazed!
Thank you, introduced in a very concise way. If I2S source and DAC impedances are not stated, how do I achieve good results? Fetch my scope and then trial and error?
Where to apply the probe(s) - at the DAC input pins and DAC digital ground point? Probe every signal line and figure out each R individually?
Old 24th October 2013, 01:13 PM   #4
Yep, its the only way unless you have simulation software.
Sometime driving two sources can be a problem as you are halving the impedances so either simulation or actual measurements is the best way.
http://www.ni.com/white-paper/3854/en/
http://www.altera.co.uk/literature/wp/wp_sgnlntgry.pdf
Howard Johnsons book on high speed design is a good reference also.
Old 24th October 2013, 05:52 PM   #5
Der, I should have said the two res solution should be twice the value, to get the same value as 1 res. my brain is not working well today.
Old 25th October 2013, 09:55 PM   #6
Im amazed!
"I should have said the two res solution should be twice the value..."
Mate, you gave me a hard time ... Before starting this thread I've read the thread stated below and so I thought: If Marce says so, there may be some truth behind it.
I2S and digital signal path - in-line resistors?
I2S line termination on dual mono DAC - 4 or 8 resistors?Hide this!Advertise here!
S.houBed DAC 132db Dual MONO pcm1794 xslavic Digital Source 30 24th February 2013 12:36 AM
ES9018 DUAL MONO DAC PCB syllable Vendor's Bazaar 7 15th September 2012 08:50 AM
Dac or Dual-Mono Amps? Reference1042 The Lounge 2 9th March 2012 12:38 AM
Need opinions on boxing a dual mono line stage phrarod Tubes / Valves 0 21st June 2010 07:08 PM
termination on I2S recommendable? weissi Digital Source 7 30th October 2002 08:11 PM
