Using Microcontroller to control sections  in amp
Old 18th October 2013, 10:20 AM   #1
sudheer is offline sudheer  India
Banned
Default Using Microcontroller to control sections in amp
Hello,
Using microcontroller to control/switch various sections of Audio amplifier device.
Example, on off switching of PSU, input selection, mute, using push button or IR remote, with display, led indicators.
I plan to work on such project, will post updates here..
My idea is to make a controller , which can switch on / switch off PSU, drive a relay board for Audio Aux Input selectors with display and push buttons.
Thank you
Sudheer
Old 18th October 2013, 03:56 PM   #2
Banned
Here is schematic and for same..
will be working on making prototype on weekends..
Old 18th October 2013, 04:54 PM   #3
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Your parts count would be far less with a PIC.
Old 19th October 2013, 01:19 AM   #4
blue_luke is offline blue_luke  Canada
blue_luke's Avatar
Why do you think so?
The part count is quite low in my opinion.
I would not do it this way but he is going in the right direction I think.
My way...
Since the upc is twiddling its thumb almost 100% of the time in these application and code lines cost nothing I would implement a sort of serial bus I2C or ISP as there a lots of neat stuff available for analogue control.
Put a remote volume control
Put some sort of mute control on the output whenever you feel it's necessary
design high-pass and low-pass filters with 2-3 slopes and some preset frequency corners. For ex: 5-12-18db / octave at 30-50-80hz etc...
multiple input selections but one thing that is often overseen is the possibility of choosing 2-3 outputs in single or multi outputs at the same time.
A VU/Peak/Average meter with various dunamic curves and release slopes
etc...
Old 19th October 2013, 01:43 AM   #5
Banned
My way...
etc...
It has
LCD Display (16pin connectors)
Mute and Power off of signals. (6 pin connectors)
Four ports used to drive relay (6 pin connectors)
I am using ULN series IC to drive Aux input relays,
Controls are using two push buttons, one for on off, another for channel select.
I want save Channel selected in 24c02, will take some time to write code, as I am not into programming, I am learning C , taking examples from blogs , re using those codes.
I will post PCB Layout later
Sudheer
Old 19th October 2013, 02:18 AM   #6
tauro0221 is offline tauro0221  United States
I am working also in something like that using a Basic Micro. Right now I have the following features.
1-Power ON/OFF using the zero crossing to prevent the inrush current.
2-Protect the speaker using a current sensor and shut down the amplifier in
case the current reached tripping point.
3-Monitor the heat sink temperature and shut down if reached tripping point.
4-Prevent the amplifier on power ON in case of a power outage.
5-Mute output on power ON/OFF
Now I am working in adding to control the +/- rail output voltages and shut down the voltage in case of high output current.
My prototype it is bean running flawless for the 8 months.
Please if you need any advice do not hesitate to ask.
Attached it is a schematic with all the options.
Old 19th October 2013, 02:26 AM   #7
kc8apf is offline kc8apf  United States
Moving to a PIC or AVR would only eliminate the EEPROM and a few resistors.
Old 19th October 2013, 04:11 AM   #8
blue_luke's Avatar
And EEPROM or flash rom ARE nice to have!
In those you can save presets, linear to nonlinear lookup tables for... whatever
Really the design shown by Sudheer is in the good direction.
Lets see what he comes up with in software terms. A design around nowadays upc is almost ( note the almost ) trivial!
The devil is in the analogue signal interface.... and the code!
Old 19th October 2013, 05:51 AM   #9
thimios is online now thimios  Greece
Default controling
It's very interesting.
All that options are useful.
Is it on your plan to share this?
Best regards.
Thimios.
Old 19th October 2013, 11:53 AM   #10
AVR and PIC typically include an EEPROM in the same package. You can usually write the code flash from the running program as well (self-programming). So, you can still have all those features w/o a separate EEPROM.
Using Microcontroller to control sections  in ampHide this!Advertise here!
determining microcontroller speed & memory size squadra Everything Else 4 2nd November 2013 05:52 PM
Hornresp - Sections gafhenderson Full Range 15 26th February 2012 01:31 PM
Hammond 125ESE and sections mpingo Tubes / Valves 0 10th January 2008 06:41 PM
parallel sections memphissound Tubes / Valves 1 21st July 2006 09:24 PM
Microcontroller based class-d amp? ukram Digital Source 21 19th January 2004 11:38 AM
