Go Back   Home > Forums > Source & Line > Digital Line Level
Old 12th October 2013, 10:17 AM   #1
Default Newclassd Dac
Hello
Have just mounted my Newclassd Dac,,(pcm1704).. the output from dac goes to Lundahl1674 trafo,,,use 600ohm to I-V, over the sekundaer side
from the Lundahl i use a 6n2p tube srrp for output
Short off the sound....lovely varm and easy to listen to,,,a good deal different to the sound of my pcm1794 dac..it will come to taste ,witch dac is best.. to my ears i like the Newclassd best
Have any other tried this Newclassd dac?
Best
Bjarne
NewClassD DAC S
Old 15th October 2013, 01:04 PM   #2
A opdate to my Newclassd dac--
the sound with the trafo and tube is realy good on acoustic music,,,,but when i play some good blues or rock,,it is a bit recessed (a bit boring )i think it must be the Lundahl trafo--because the pcm1794 dac direct to tube output has more bite...but not so musical
After advice from Lars from Newclassd ..i got his Discrete opamp mounted
it gave a total different sound..realy dynamic,,,i can tell more about the sound when the dac is settled in (maybe 50 hours or so)
best Bjarne
newclassd: the better class d amp? zycomatique Class D 32 10th January 2014 02:46 PM
NewClassD Mangold Class D 0 12th April 2012 10:33 AM
Newclassd Gold Series PH Solid State 4 28th October 2009 02:31 PM
Hypex or NewclassD? Which is the Best Class D Amp there is???? Strummer61 Class D 93 21st October 2008 09:55 AM
NewClassD UWB regulator wheezer Digital Source 2 31st July 2008 03:35 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
