New Hifimediy ES9023 DAC with I2S board - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 7th October 2013, 02:56 PM   #1
Default New Hifimediy ES9023 DAC with I2S board
I just came across this "new" DAC of Hifimediy:
Hifimediy ES9023 DAC, I2S and left justified input, 192Khz/24bit
It is a DAC with I2S input: any opinion on this. I'd like to use it with a RPi. Is it just as simple as adding an I2S connection to the RPi, connect it to this DAC (incl. 5V DC from the IO-port) and then connect this DAC to my poweramp? Or am I overlooking something.
Old 22nd February 2014, 07:48 AM   #2
I did. It is working with Volumio 1.2beta(Volumio 1.1beta didn't work).
I also used 48 mhz oscillator as internal clock. I can play 24/192 files.
Old 27th February 2014, 03:36 AM   #3
Peterma is offline Peterma  Australia
How does it sound?
Old 27th February 2014, 01:15 PM   #4
I can say that it sounds very good.
Old 27th February 2014, 02:15 PM   #5
boris81 is offline boris81  United States
For the best sound quality you should use a dedicated linear regulated power supply and a very accurate internal clock (in asynchronous mode).
Old 27th February 2014, 11:31 PM   #6
Just asked because I am in two minds whether to go towards this one or subbu which I have bare PCBs waiting to order parts, the parts for subbu cost more than this already built.
Old 19th March 2014, 08:05 PM   #7
Thanks for your response. Which oscillator did you use?
Hifimediy ES9023+TE7022 24/96 USB Dac sharpi31 Digital Line Level 401 6th January 2016 01:57 PM
ES9023 I2S Input DAC incl. JG Filter Buffer curryman Vendor's Bazaar 54 14th November 2015 10:18 PM
Bragi, an Asynchronous ES9023 DAC with isolated I2S Input and Alps RK27 Volume pot Neutrality Digital Line Level 40 20th July 2014 11:47 PM
Hifimediy ES9023+TE7022 24/96 USB Dac -> I2S elagil Digital Line Level 5 19th May 2013 11:52 AM
115 V wiring for Hifimediy Sabre Coax/Optical DAC ES9023 +CS8416 192k/24 AngleCard48 Construction Tips 2 26th December 2012 01:34 PM
Copyright 1999-2017 diyAudio
